SK6203/SK6211/SK6281 Usb Flash
新品快讯
30人已加入
SK6203/SK6211/SK6281 Usb Flash Disk Controller
SK6211是一個效能加強版的隨身碟控制器,它能符合USB2.0的規格並能以極低功率來滿足USB bus-power的需求。
SK6211 的ECC糾正能力高達13bit,專為50nm MLC 特別設計。
Features:
Worldwide first UFD controller for 50nm NAND:
13-bit BCH or 8-symbol RS error control coding (ECC) suitable for MLC.
Sufficient embedded buffer for 4K page NAND.
Passing FCC/CE ClassB with choke.
The least passive components, about 12 pcs.
Outstanding R/W performance:
HDBench : Read: 32MB/s and Write: 23MB/s.
ReadyBoost :
>5 MB/sec throughput for random 4KB reads and,
>3 MB/sec throughput for random 512KB writes
Enable Multi-Partition features:
One Read-only Partition, two Read-Write Partitions and one Hidden Partition.
Each Read-Write Partition can be divided into Public Zone and Private Zone further.
NAND Interface:
Either single channel (x8 data width) or dual channel (x16 data width)
Support up to 4 CE pins, i.e. 8 NAND chips.
Up to 32GBytes addressing space.
SK6203是一個效能加強版的隨身碟控制器,它能符合USB2.0的規格並能以極低功率來滿足USB bus-power的需求。
SK6203 當隨身碟的容量越來越大,保密之需求也隨之升高,SK6203提供了硬體之AES 加/密引擎,以保護儲存於隨身碟之資料不被竊取。
SK6203 的ECC糾正能力高達13bit,專為50nm MLC 特別設計。
Features:
Hardware-based AES encryption
Encryption could be enable and disable by programming.
The key size is selectable, 128/192/256 bits.
ReadyBoost :
NAND Interface
SK6281是一個效能加強版的隨身碟控制器,它能符合USB2.0的規格並能以極低功率來滿足USB bus-power的需求。
SK6281採用雙通道架構時,其傳輸速率已接近 USB2.0的極限值,讀取/寫入的速率分為 32/23 MB/S。
Features:
ReadyBoost :
NAND Interface:
  • 相关推荐
  • 热点推荐
  • Disk
