液晶电视
| MAX6960 EV kit #1 | MAX6960 EV kit #2 | MAX6960 EV kit #3 | MAX6960 EV kit #4 | MAX6960 EV kit #5 |
| JU1:(2-3) | JU1:(2-3) | JU1:(2-3) | JU1:(2-3) | JU1:(2-3) |
| JU2:(2-3) | JU2:(2-3) | JU2:(2-3) | JU2:(2-3) | JU2:(2-3) |
| JU3:(1-2) | JU3:(2-3) | JU3:(2-3) | JU3:(2-3) | JU3:(2-3) |
| JU4:(2-3) | JU4:(2-3) | JU4:(2-3) | JU4:(2-3) | JU4:(2-3) |
| JU5:(2-3) | JU5:(2-3) | JU5:(2-3) | JU5:(2-3) | JU5:(2-3) |
| JU6:(1 only) | JU6:(1 only) | JU6:(1 only) | JU6:(1 only) | JU6:(1-2) |
| JU7:(2-3) | JU7:(2-3) | JU7:(2-3) | JU7:(2-3) | JU7:(2-3) |
| JU8:(2-3) | JU8:(2-3) | JU8:(2-3) | JU8:(2-3) | JU8:(2-3) |
| JU9:(1-2) | JU9:(2-3) | JU9:(2-3) | JU9:(2-3) | JU9:(2-3) |
| JU10:(2-3) | JU10:(2-3) | JU10:(2-3) | JU10:(2-3) | JU10:(2-3) |
| JU11:(2-3) | JU11:(2-3) | JU11:(2-3) | JU11:(2-3) | JU11:(2-3) |
| JU12:(OPEN) | JU12:(SHORT) | JU12:(SHORT) | JU12:(SHORT) | JU12:(SHORT) |
| JU13:(1-2) | JU13:(2-3) | JU13:(2-3) | JU13:(2-3) | JU13:(2-3) |
| JU14:(1 only) | JU14:(1-2) | JU14:(1-2) | JU14:(1-2) | JU14:(1-2) |
| JU15:(1-2) | JU15:(1 only) | JU15:(1 only) | JU15:(1 only) | JU15:(1 only) |
| JU16:(1-2) | JU16:(1-2) | JU16:(1-2) | JU16:(1-2) | JU16:(1-2) |
| JU17:(1 only) | JU17:(1-2) | JU17:(1-2) | JU17:(1-2) | JU17:(1-2) |
| Step | Operation | Register Address | Description |
| 1 | GPI RESET | N/A | RESET was held low for 2.5ms after power-up to properly apply power to all five MAX6960 devices while power is stable. RESET was then driven high for 100ms. |
| 2 | SPI:16-bit address mode write | Panel Configuration Register (0x0D) | Sets:
| 3 | SPI:16-bit address mode write | Global Driver Devices Register (0x0E) | Sets:
| 4 | SPI: 16-bit address mode write | Global Driver Rows Register (0x0F) | Sets:
| 5 | Delay | N/A | Adds a required 450ms delay after steps 1 through 4 above. All the MAX6960 devices require this time to properly configure themselves. |
| 6 | RS-232 serial COM port | N/A | Waits for stock quote bytes to be sent from the Windows program to the MAXQ2000 through the RS-232 serial COM port. |
