通信设计应用
| VFB | The voltage present at the feedback node of the DC-DC converter. |
| VAPD (max) | The maximum voltage to which the APD bias can be set under worst-case conditions. |
| VAPD (min) | The minimum voltage to which the APD bias can be set under worst-case conditions. |
| STEP (max) | The maximum calculated voltage step that can occur between two adjacent DAC codes. |
| STEP (avg) | The average voltage step size that occurs across the full range. |
| VSTEP +20% | The voltage step size when the variable resistor is at the maximum of the process range (+20%). |
| VSTEP -20% | The voltage step size when the variable resistor is at the minimum of the process range (-20%). |
| VAPD +20% | The APD bias voltage when the variable resistor is at the maximum of the process range (+20%). |
| VAPD -20% | The APD bias voltage when the variable resistor is at the minimum of the process range (-20%). |
