电源设计应用
| TEMP ALARM HI TEMP WARN HI |
00h, 04h | S | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| 01h, 05h | 2-1 | 2-2 | 2-3 | 2-4 | 2-5 | 2-6 | 2-7 | 2-8 | |
| TEMP ALARM LO TEMP WARN LO |
02h, 06h | S | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| 03h, 07h | 2-1 | 2-2 | 2-3 | 2-4 | 2-5 | 2-6 | 2-7 | 2-8 | |
| VCC ALARM HI VCC WARN HI |
08, 0C, 10, 14, 18, 1C, 20, 24, 25, 2Ch | 215 | 214 | 213 | 212 | 211 | 210 | 29 | 28 |
| MON1-4 ALARM HI MON1-4 WARN HI |
09, 0D, 11, 15, 19, 1D, 21, 25, 29, 2Dh | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| VCC ALARM LO VCC WARN LO |
0A, 0E, 12, 16, 1A, 1E, 22, 26, 2A, 2Eh | 215 | 214 | 213 | 212 | 211 | 210 | 29 | 28 |
| MON1-4 ALARM LO MON1-4 WARN LO |
0B, 0F, 13, 17, 1B, 1F, 23, 27, 2B, 2Fh | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| PW2 EE | 30h-5Fh | EE | EE | EE | EE | EE | EE | EE | EE |
| TEMP VALUE | 60h | S | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| 61h | 2-1 | 2-2 | 2-3 | 2-4 | 2-5 | 2-6 | 2-7 | 2-8 | |
| VCC VALUE, MON1-4 VALUE |
62, 64, 66, 68, 6Ah | 215 | 214 | 213 | 212 | 211 | 210 | 29 | 28 |
| 63, 65, 67, 69. 6Bh | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 | |
| RESERVED | 6C, 6Dh | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| STATUS | 6Eh | FETG STATUS |
SOFT FETG |
RSVD | TX-F RESET |
SOFT TX-D |
TX-F STATUS |
LOS STATUS |
RDYB |
| UPDATE | 6Fh | TEMP RDY |
VCC RDY | MON1 RDY |
MON2 RDY |
MON3 RDY |
MON4 RDY |
RSVD | RSVD |
| ALARM3 | 70h | TEMP HI | TEMP LO | VCC HI | VCC LO | MON1 HI | MON1 LO | MON2 HI | MON2 LO |
| ALARM2 | 71h | MON3 HI | MON3 LO | MON4 HI | MON4 LO | RSVD | RSVD | RSVD | RSVD |
| ALARM1 | 72h | RSVD | RSVD | RSVD | RSVD | BIAS HI | RSVD | TX-P HI | TX-P LO |
| ALARM0 | 73h | RSVD | RSVD | RSVD | RSVD | BIAS MAX | RSVD | RSVD | RSVD |
| WARN3 | 74h | TEMP HI | TEMP LO | VCC HI | VCC LO | MON1 HI | MON1 LO | MON2 HI | MON2 LO |
| WARN2 | 75h | MON3 HI | MON3 LO | MON4 HI | MON4 LO | RSVD | RSVD | RSVD | RSVD |
| RESERVED | 76, 77h | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| DOUT | 78h | RSVD | RSVD | RSVD | RSVD | D3 OUT | D2 OUT | D1 OUT | D0 OUT |
| DIN | 79h | RSVD | RSVD | INV LOSI | MUX LOSI | D3 IN | D2 IN | D1 IN | D0 IN |
| RESERVED | 7Ah | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| PASSWORD ENTRY |
7Bh | 231 | 230 | 229 | 228 | 227 | 226 | 225 | 224 |
| 7Ch | 223 | 222 | 221 | 220 | 219 | 218 | 217 | 216 | |
| 7Dh | 215 | 214 | 213 | 212 | 211 | 210 | 29 | 28 | |
| 7Eh | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 | |
| TABLE SELECT | 7Fh | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| PW1 EEPROM | 80h–F7h | EE | EE | EE | EE | EE | EE | EE | EE |
| ALARM3 | F8h | TEMP HI | TEMP LO | VCC HI | VCC LO | MON1 HI | MON1 LO | MON2 HI | MON2 LO |
| ALARM2 | F9h | MON3 HI | MON3 LO | MON4 HI | MON4 LO | RSVD | RSVD | RSVD | RSVD |
| ALARM1 | FAh | RSVD | RSVD | RSVD | RSVD | BIAS HI | RSVD | TX-P HI | TX-P LO |
| ALARM0 | FBh | RSVD | RSVD | RSVD | RSVD | BIAS MAX | RSVD | RSVD | RSVD |
| WARN3 | FCh | TEMP HI | TEMP LO | VCC HI | VCC LO | MON1 HI | MON1 LO | MON2 HI | MON2 LO |
| WARN2 | FDh | MON3 HI | MON3 LO | MON4 HI | MON4 LO | RSVD | RSVD | RSVD | RSVD |
| RESERVED | FE-FFh | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| MODE | 80h | SEEB | RSVD | RSVD | M4DAC-EN | AEN | MOD-EN | APC-EN | BIAS-EN |
| T INDEX | 81h | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| MOD DAC | 82h | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| APC DAC | 83h | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| V INDEX | 84h | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| M4DAC | 85h | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| DEVICE ID | 86h | 0 | 1 | 1 | 0 | 0 | 1 | 0 | 1 |
| DEVICE VER | 87h |
| UPDATE RATE | 88h | 0 | 0 | 0 | 0 | SR3 | SR2 | SR1 | SR0 |
| CONFIG | 89h | FETG DIR | TX-F EN | RSVD | ASEL | RSVD | RSVD | RSVD | RSVD |
| START-UP STEP | 8Ah | 212 | 211 | 210 | 29 | 28 | 27 | 26 | 25 |
| MOD RANGING | 8Bh | RSVD | RSVD | RSVD | RSVD | RSVD | MOD2 | MOD1 | MOD0 |
| DEVICE ADDRESS | 8Ch | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| COMP RANGING | 8Dh | RSVD | BIAS2 | BIAS1 | BIAS0 | RSVD | APC2 | APC1 | APC0 |
| RIGHT SHIFT1 | 8Eh | RSVD | MON12 | MON11 | MON10 | RSVD | MON22 | MON21 | MON20 |
| RIGHT SHIFT0 | 8Fh | RSVD | MON32 | MON31 | MON30 | RSVD | MON42 | MON41 | MON40 |
| RESERVED | 90–91h | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| VCC SCALE MON1-4 SCALE |
92, 94, 96, 98, 9Ah | 215 | 214 | 213 | 212 | 211 | 210 | 29 | 28 |
| 93, 95, 97, 99, 9Bh | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 | |
| RESERVED | 9C–A1h | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| VCC OFFSET MON1-4 OFFSET |
A2, A4, A6, A8, AAh | S | S | 215 | 214 | 213 | 212 | 211 | 210 |
| A3, A5, A7, A9, ABh | 29 | 28 | 27 | 26 | 25 | 24 | 23 | 22 | |
| RESERVED | AC-ADh | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| TEMP OFFSET | AEh | S | 28 | 27 | 26 | 25 | 24 | 23 | 22 |
| AFh | 21 | 20 | 2-1 | 2-2 | 2-3 | 2-4 | 2-5 | 2-6 | |
| PW1 | B0h | 231 | 230 | 229 | 228 | 227 | 226 | 225 | 224 |
| B1h | 223 | 222 | 221 | 220 | 219 | 218 | 217 | 216 | |
| B2h | 215 | 214 | 213 | 212 | 211 | 210 | 29 | 28 | |
| B3h | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 | |
| PW2 | B4h | 231 | 230 | 229 | 228 | 227 | 226 | 225 | 224 |
| B5h | 223 | 222 | 221 | 220 | 219 | 218 | 217 | 216 | |
| B6h | 215 | 214 | 213 | 212 | 211 | 210 | 29 | 28 | |
| B7h | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 | |
| FETG ENABLE1 | B8h | TEMP EN | VCC EN | MON1 EN | MON2 EN | MON3 EN | MON4 EN | RSVD | RSVD |
| FETG ENABLE0 | B9h | HTXP EN | LTXP EN | BIAS HI EN | BIAS MAX EN | RSVD | RSVD | RSVD | RSVD |
| TX-F ENABLE1 | BAh | TEMP EN | VCC EN | MON1 EN | MON2 EN | MON3 EN | MON4 EN | RSVD | RSVD |
| TX-F ENABLE0 | BBh | HTXP EN | LTXP EN | BIAS HI EN | BIAS MAX EN | RSVD | RSVD | RSVD | FETG EN |
| HTXP | BCh | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| LTXP | BDh | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| HBIAS | BEh | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| MAX IBIAS | BFh | 212 | 211 | 210 | 29 | 28 | 27 | 26 | 25 |
| DPU | C0h | RSVD | RSVD | INV LOSI | MUX LOSI | D3 CNTL | D2 CNTL | D1 CNTL | D0 CNTL |
| RESERVED | C1–C3h | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| DAC1 | C4h | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 |
| RESERVED | C5–C6h | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
| M4 LUT | C7h | RSVD | RSVD | RSVD | RSVD | RSVD | RSVD | DBL_SB | UP_LOWB |
| MAN IBIAS | F8h | RSVD | RSVD | 212 | 211 | 210 | 29 | 28 | 27 |
| F9h | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 | |
| MAN_CNTL | FAh | RSVD | RSVD | RSVD | RSVD | RSVD | RSVD | RSVD | MAN_CLK |
| BIAS DAC | FBh | 0 | 0 | 212 | 211 | 210 | 29 | 28 | 27 |
| FCh | 27 | 26 | 25 | 24 | 23 | 22 | 21 | 20 | |
| RESERVED | FD-FEh | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
