新品快讯
MAX8891, MAX8892 高PSRR、低压差、150mA线性稳压器
MAX8891, MAX8892 概述
The MAX8891/MAX8892 low-dropout (LDO) linear regulators are designed to deliver up to 150mA continuous output current. These regulators achieve a low 120mV dropout for 120mA load current.
The MAX8891 only requires an input/output capacitor, hence achieving the smallest PCB area. The MAX8892's output voltage can be adjusted with an external divider.
The MAX8891 is preset to a variety of voltages in the 1.5V to 4.5V range. Designed with a p-channel MOSFET series pass transistor, the MAX8891/MAX8892 maintain very low ground current (40µA).
The regulators are designed and optimized to work with low-value, low-cost ceramic capacitors. The MAX8891/MAX8892 require only 1µF (typ) of output capacitance for stability with any load. When disabled, current consumption drops to below 1µA.
These regulators are available in a tiny 5-pin SC70 package.
MAX8891, MAX8892 关键特性
MAX8891, MAX8892 应用/使用
基站
Bluetooth便携式无线装置及配件
蜂窝、无绳电话
数码相机
PDA与掌上电脑
个人立体声装置
便携式电池供电产品
无线LAN
