真空荧光显示器件参考设计为汽车应用-Vacuum Fluor
汽车电路图
59人已加入
Abstract: This article describes a vacuum fluorescent display (VFD) and some ideal applications for the technology. The reference design then shows how to use a MAX15005 power-supply controller in a flyback topology to obtain multiple output voltages for a vacuum fluorescent display.
Introduction
This reference design shows a solution for obtaining the drive voltage required for a vacuum fluorescent display (VFD) power supply in automotive applications. The design includes the complete schematic, and presents the bill of materials (BOM), load/line regulation measurements, and test results.
VFD Basics
The VFD is composed of three basic electrodes—the cathode filaments, anodes (phosphor), and grids—under a high-vacuum condition in a glass envelope. The cathode consists of fine tungsten wires, coated by alkaline earth metal oxides which emit electrons. The grids are a thin metal mesh, which controls and diffuses electrons emitted from the cathode. The anodes are conductive electrodes on which the phosphor is printed to indicate characters, icons, or symbols. Electrons emitted from the cathode are accelerated with positive potential applied to both grid and anode; upon collision with the anode the electrons excite the phosphor to emit light. The desired illuminated patterns can be achieved by controlling the positive or negative potentials on each grid and anode. The anode and grid require a DC-regulated voltage to avoid flickering of the display. For driving large VFDs, the cathode requires AC drive to prevent luminance slant, i.e., the difference in brightness from one side of the display to the other. A frequency range of 20kHz to 200kHz is recommended to avoid audible noise and flicker.
Design Specifications and Setup
This reference design features the MAX15005 power-supply controller optimized for automotive and VFD applications. The application circuit is designed to meet the following specifications:
  • VIN: 9V to 16V continuous, 5.5V to 40V transient
  • VANODE: 77VDC ±10% at 18mA (typ), 58mA (max)
  • VGRID: 55VDC ±10% at 14mA (typ), 41mA (max)
  • VFILAMENT: 3.1VAC ±10% at 350mA (typ), 385mA (max)
  • Output ripple: 77V: 1VP-P; 55V: 0.5VP-P
  • Line regulation, VIN = 9V to 16V:
    VANODE = ±3%
    VGRID = ±3%
    VFILAMENT = ±5%
  • Load regulation: (see Line/Load Regulation Data section below)
  • Switching frequency: 22kHz
  • Temperature: -40°C to 125°C
The schematic for the above specifications is shown in Figure 1. In this design MAX15005A is used in the flyback configuration for obtaining three output voltages.
显示器
Figure 1. Schematic of the MAX15005B flyback converter for FSW = 22kHz.
The bill of materials (BOM) for this reference design is given in Table 1.
Table 1. Bill of Materials for VFD Reference Design
Designator Value Description Part Number Footprint Manufacturer Quantity
C1, C11, C12 10nF, 100V Capacitor C2012X7R2A103K 0805 TDK® 3
C2, C7 270pF, 100V Capacitor GRM188R72A271KA01D 0805 Murata® 2
C3, C5 100nF, 100V Capacitor C2012X7R2A104K 0805 TDK 2
C4 3.3nF, 25V Capacitor 08053A332FAT2A 0805 AVX® Corporation 1
C6, C8 1µF, 50V Capacitor C3216X7R1H105K 1206 TDK 2
C9 100pF, 100V Capacitor GRM2165C2A101JA01D 0805 Murata 1
C10 330µF, 35V Capacitor SMD TDK 1
C13, C14, C15, C16, C17, C18 2.2µF, 100V Capacitor GRM32ER72A225KA35L 1210 Murata 6
D1 3A, 400V Diode S3G SMC Vishay® 1
D2, D3, D4 1A, 200V Diode ES1D SMA Vishay 3
Q1 11A, 55V n-FET BUK92150-55A NXP® 1
R1 32.4kΩ Resistor SMD, 5%, 0.125W 0805 KOA 1
R2, R9, R17 100kΩ Resistor SMD, 5%, 0.125W 0805 KOA 3
R3 21kΩ Resistor SMD, 1%, 0.125W 0805 KOA 1
R4, R6 100kΩ Resistor SMD, 1%, 0.250W 1206 KOA 2
R5 1.62kΩ Resistor SMD, 1%, 0.125W 0805 KOA 1
R7 1.43kΩ Resistor SMD, 1%, 0.125W 0805 KOA 1
R8 10kΩ Resistor SMD, 5%, 0.125W 0805 KOA 1
R10 499Ω Resistor SMD, 1%, 0.125W 0805 KOA 1
R11 100Ω Resistor SMD, 5%, 0.125W 0805 KOA 1
R12 1kΩ Resistor SMD, 1%, 0.333W 1210 KOA 1
R13 0.06Ω Resistor SMD, 1%, SL1 SL1 KOA 1
R14 33kΩ Resistor SMD, 5%, 0.125W 0805 KOA 1
R15, R16 1.0Ω Resistor SMD, 1%, 0.250W 1206 KOA 2
T1 54µH Transformer DCT20EFD-UxxSOA5 SMD TDK 1
Z1 9.1V Zener diode 1SMB5924BT SMB Vishay 1
IC1 MAX15005B Boost controller MAX15005BAUE+ 16TSSOP MAXIM® 1
Waveform Measurements
The following test results were generated from the board built for evaluating the circuit.
Test conditions: VIN = 14V; RANODE = 3.3kΩ; RGRID = 3.3kΩ; RFILAMENT = 8Ω.
显示器
Ch1: MOSFET Q1 drain voltage (VDRAIN); Ch2: current-sense voltage across R13 (VISENSE).
显示器
Ch1: anode output voltage ripple; Ch2: grid output voltage ripple.
显示器
Ch1: filament positive node voltage (VF1); Ch2: filament negative node voltage (VF2).
显示器
M: effective filament voltage (VF1 - VF2)
The following line/load regulation data was taken from the test board over the input voltage range and load.
VIN I77 (mA) I55 (mA) V77 (VDC) V55 (VDC) VF (VRMS)
9.0 7.7 5.5 77.0 55.2 2.41
  7.7 16.7 77.0 55.0 2.64
  7.7 44.0 77.0 54.8 3.03
  23.0 5.5 77.0 55.4 2.82
  23.0 16.7 77.0 55.2 2.97
  23.0 44.0 77.0 55.0 3.24
  61.6 5.5 77.0 55.8 3.35
  61.6 16.7 77.0 55.6 3.43
  61.6 44.0 77.0 55.4 3.62
14.0 7.7 5.5 77.0 55.2 2.52
  7.7 16.7 77.0 55.0 2.75
  7.7 44.0 77.0 54.8 3.14
  23.0 5.5 77.0 55.4 2.80
  23.0 16.7 77.0 55.2 3.08
  23.0 44.0 77.0 55.0 3.36
  61.6 5.5 77.0 55.8 3.50
  61.6 16.7 77.0 55.7 3.59
  61.6 44.0 77.0 55.4 3.79
16.0 7.7 5.5 77.0 55.2 2.63
  7.7 16.7 77.0 55.0 2.86
  7.7 44.0 77.0 54.8 3.25
  23.0 5.5 77.0 55.4 3.04
  23.0 16.7 77.0 55.2 3.20
  23.0 44.0 77.0 55.0 3.49
  61.6 5.5 77.0 54.8 3.25
  61.6 16.7 77.0 55.0 3.49
  61.6 44.0 77.0 55.4 3.92
Conclusion
This application note presents a power-supply reference design for driving a typical vacuum fluorescent display in an automotive application. The design was built to the specifications presented here. The design was then tested. The circuit schematic, BOM, and typical waveforms have been presented.
AVX is a registered trademark of AVX Corporation.
Maxim is a registered trademark of Maxim Integrated Products, Inc.
Murata is a registered trademark of Murata Manufacturing Co., Ltd.
NXP is a registered trademark of NXP Semiconductors.
TDK is a registered trademark of TDK Corporation.
Vishay is a registered trademark of Vishay Intertechnology, Inc.
