在PL设计中使用MPSoC EMIO GPIO
MPSoC 为PL提供了96个GPIO,通过EMIO管脚链接到PL。
普通PL设计,一般只会用到几个GPIO管脚。可以使用Vivado IPI中的Slice IP, 从其中分出指定数量的管脚。
Vivado
Slice配置界面
上图中,输入宽度是95,因为pl_reset占用率一个管脚。slice从输入中提取emio的[7:5]三位,作为输出。
Xilinx Linux 中缺省使能了GPIO驱动。对于MPSoC,检查目录/sys/class/gpio,可以看到设备gpiochip338。
# ls -l /sys/class/gpio total 0 export gpiochip306 -> ../../devices/platform/amba/ff020000.i2c/i2c-0/0-0021/gpio/gpiochip306 gpiochip322 ->../../devices/platform/amba/ff020000.i2c/i2c-0/0-0020/gpio/gpiochip322 gpiochip338 -> ../../devices/platform/amba/ff0a0000.gpio/gpio/gpiochip338 unexport # ls /sys/class/gpio/gpiochip338/ -l total 0 base device -> ../../../ff0a0000.gpio label ngpio power subsystem -> ../../../../../../class/gpio uevent
Linux GPIO Driver下的GPIO使用,可以参考Linux GPIO Driver;GPIO User Space App。
从上述文章可以看到,使用GPIO不简单。
为了简化使用GPIO,编写了以下脚本。使用下列脚本,一条命令就能设置一个GPIO的输出值。脚本接受两个输入参数。第一个参数表示GPIO编号,MIO GPIO从0开始,EMIO GPIO从78开始。第二个参数是输出值。如果输出值是1,可以省略第二个参数。
#/bin/bash function gpio_output_func() {    #echo "No.1 parameter: $1"    #echo "No.2 parameter: $2"            # MPSoC GPIO number.    gpio_num=$[338+$1]        # MPSoC EMIO GPIO number.    # gpio_num=$[338+78+$1]        echo "Set GPIO number: $gpio_num to value: $2"    if [ ! -f /sys/class/gpio/gpio$gpio_num/direction ]; then        #  Export a GPIO pin        echo $gpio_num > /sys/class/gpio/export    fi              #  Read the direction and value from the GPIO pin */    # ls -l /sys/class/gpio/gpio$gpio_num/    gpio_direction=`cat /sys/class/gpio/gpio$gpio_num/direction`    gpio_value=`cat /sys/class/gpio/gpio$gpio_num/value`    echo -e "GPIO number: $gpio_num previous direction: $gpio_direction, previous value: $gpio_value"          #  Set the direction to an output and write a value 1 to GPIO pin */    echo out > /sys/class/gpio/gpio$gpio_num/direction    echo $2 > /sys/class/gpio/gpio$gpio_num/value    gpio_direction=`cat /sys/class/gpio/gpio$gpio_num/direction`    gpio_value=`cat /sys/class/gpio/gpio$gpio_num/value`    echo -e "GPIO number: $gpio_num current direction: $gpio_direction, current value: $gpio_value" } # Check GPIO chip gpio_chip=`cat /sys/class/gpio/gpiochip338/label` gpio_base=`cat /sys/class/gpio/gpiochip338/base` gpio_number=`cat /sys/class/gpio/gpiochip338/ngpio` echo "MPSoC GPIO information: chip: $gpio_chip, base: $gpio_base, number: $gpio_number." # cat /sys/class/gpio/gpiochip338/label # cat /sys/class/gpio/gpiochip338/base # cat /sys/class/gpio/gpiochip338/ngpio # The above line indicates that gpio 0th pin starts from 338 and ends at 511 (GPIO has total 174 pins for ZynqMP) if [ "$2" = "" ]; then    gpio_output_func $1 1 else    gpio_output_func $1 $2 fi
执行记录
# ./gpio_single_output.sh 81 MPSoC GPIO information: chip: zynqmp_gpio, base: 338, number: 174. Set GPIO number: 419 to value: 1 GPIO number: 419 previous direction: out, previous value: 0 GPIO number: 419 current direction: out, current value: 1 # ./gpio_single_output.sh 81 0 MPSoC GPIO information: chip: zynqmp_gpio, base: 338, number: 174. Set GPIO number: 419 to value: 0 GPIO number: 419 previous direction: out, previous value: 1 GPIO number: 419 current direction: out, current value: 0
Vivado
