MAX4940, MAX4940A 双/四通道、单/双极性、高压数字脉冲发生器
The MAX4940/MAX4940A integrated circuits generate high-voltage, high-frequency, unipolar or bipolar pulses from low-voltage logic inputs. These quad/dual pulsers feature independent logic inputs, independent high-voltage pulser outputs with active clamps and independent high-voltage supply inputs.
The MAX4940/MAX4940A feature quad, high-voltage pulsers with 8.5Ω output impedance for the high-voltage outputs and a 21Ω impedance for the active clamp. The high-voltage outputs can provide 2.0A (typ) output current.
All devices use two logic inputs per channel to control the positive and negative pulses. The MAX4940/MAX4940A have a dedicated input to control the active clamp. All devices feature an independent enable input EN. All digital inputs are CMOS compatible. (See Ordering Information/Selector Guide.)
The MAX4940/MAX4940A are available in a 56-pin, 8mm x 8mm, TQFN exposed pad package and are specified over the 0°C to +70°C commercial temperature range.
Warning: Exercise caution. The MAX4940/MAX4940A are designed to operate with high voltages.
High-Density Quad-Channel Pulser in One Package
0 to +220V Unipolar or ±110V Bipolar Outputs
8.5Ω (typ) Output Impedance and 2.0A (typ) Output Current
27Ω (typ) Always-On Active Clamp with Integrated Blocking Diodes
Integrated Output Diodes (MAX4940A Only)
No Special Power-Supply Sequencing Required for Trilevel Applications
Matched Rise/Fall Times and Matched Propagation Delays
CMOS-Compatible Logic Inputs
56-Pin, 8mm x 8mm, TQFN Package
应用/使用
清洗设备
探伤检测
压阻式驱动器
测试仪表
超声医疗成像
