MAX6816, MAX6817, MAX6818应用电路(
IC应用电路图
512人已加入
MAX6816, MAX6817, MAX6818应用电路(ESD保护、单/双/八通道、CMOS开关去抖器)
The MAX6816/MAX6817/MAX6818 are single, dual, and octal switch debouncers that provide clean interfacing of mechanical switches to digital systems. They accept one or more bouncing inputs from a mechanical switch and produce a clean digital output after a short, preset qualification delay. Both the switch opening bounce and the switch closing bounce are removed. Robust switch inputs handle ±25V levels and are ±15kV ESD-protected for use in harsh industrial environments. They feature single-supply operation from +2.7V to +5.5V. Undervoltage lockout circuitry ensures the output is in the correct state upon power-up.
The single MAX6816 and dual MAX6817 are offered in SOT packages and require no external components. Their low supply current makes them ideal for use in portable equipment.
The MAX6818 octal switch debouncer is designed for data-bus interfacing. The MAX6818 monitors switches and provides a switch change-of-state output (CH-bar), simplifying microprocessor (µP) polling and interrupts. Additionally, the MAX6818 has three-state outputs controlled by an enable (EN-bar) pin, and is pin-compatible with the LS573 octal latch (except for the CH-bar pin), allowing easy interfacing to a digital data bus.
通道
典型工作电路
  • 相关推荐
  • 热点推荐
  • 通道
