MAX7360 IC接口键盘开关控制器和LED驱动器/GPI
新品快讯
29人已加入
MAX7360 I²C接口键盘开关控制器和LED驱动器/GPIO,集成ESD保护
The MAX7360 I2C-interfaced peripheral provides microprocessors with management of up to 64 key switches, with an additional eight LED drivers/GPIOs that feature constant-current, PWM intensity control, and rotary switch control options. The key-switch drivers interface with metallic or resistive switches with on resistances up to 5k. Key inputs are monitored statically, not dynamically, to ensure low-EMI operation.
The MAX7360 features autosleep and autowake modes to further minimize the power consumption of the device. The autosleep feature puts the device in a low-power state (1µA typ) after a sleep timeout period. The autowake feature configures the MAX7360 to return to normal operating mode from sleep upon a keypress.
The key controller debounces and maintains a FIFO of keypress and release events (including autorepeat, if enabled). An interrupt (active-low INTK) output can be configured to alert keypresses, as they occur, or at maximum rate.
There are eight open-drain I/O ports, which can be used to drive LEDs. The maximum constant-current level for each open-drain port is 20mA. The intensity of the LED on each open-drain port can be individually adjusted through a 256-step PWM control. An input port pair (PORT6, PORT7) can be configured to accept 2-bit gray code inputs from a rotary switch. In addition, if not used for key-switch control, up to six column pins can be used as general-purpose open-drain outputs (GPOs) for LED drive or logic control.
The MAX7360 is offered in a 40-pin (5mm x 5mm) thin QFN package with an exposed pad, and a small 36-bump wafer level package (WLP) for cell phones, pocket PCs, and other portable consumer electronic applications. The MAX7360 operates over the -40°C to +85°C extended temperature range.
 MAX7360,pdf datasheet
  • Integrated ESD Protection
    • ±8kV IEC 61000-4-2 Contact Discharge
    • ±15kV IEC 61000-4-2 Air Gap Discharge
  • +14V Tolerant, Open-Drain I/O Ports Capable of Constant-Current LED Drive
  • Rotary Switch-Capable Input Pair (PORT6, PORT7)
  • 256-Step PWM Individual LED Intensity Control
  • Individual LED Blink Rates and Common LED Fade In/Out Rates from 256ms to 4096ms
  • FIFO Queues Up to 16 Debounced Key Events
  • User-Configurable Key Debounce (9ms to 40ms)
  • Keyscan Uses Static Matrix Monitoring for Low EMI Operation
  • +1.62V to +3.6V Operation
  • Monitors Up to 64 Keys
  • Key-Switch Interrupt (active-low INTK) on Each Debounced Event/FIFO Level, or End of Definable Time Period
  • Port Interrupt (active-low INTI) for Input Ports for Special-Key Functions
  • 400kbps, +5.5V Tolerant 2-Wire Serial Interface with Selectable Bus Timeout
  • Four I2C Address Choices
  • 蜂窝电话
     手持式游戏机
     仪表
     PDA
     便携式消费类电子
     打印机
    • 相关推荐
    • 热点推荐
    • ESD
