ADB wifi连接多台鸿蒙设备的准备工作
首先将两台鸿蒙设备插入电脑的usb上
查看两台鸿蒙设备的deviceid
C:\Users\Administrator》adb devices
* daemon not running; starting now at tcp:5037
* daemon started successfully
List of devices attached
FRU6R2011500QWER unauthorized
MVT5T1970300ABCD unauthorized
切换成wifi调试,将以下命令依次输入
adb -s MVT5T1970300ABCD tcpip 55555
restarting in TCP mode port: 55555
adb -s FRU6R2011500QWER tcpip 55556
restarting in TCP mode port: 55556
依次进入每台鸿蒙设备看一下上面的ip地址
依次连接两台鸿蒙设备
C:\Users\Administrator》adb connect 192.168.0.10:55555
connected to 192.168.0.10:55555
C:\Users\Administrator》adb connect 192.168.0.20:55556
connected to 192.168.0.20:55556
#试错,看看重复连会怎么样
already connected to 192.168.0.10:55555
使用scrcpy 连接一台鸿蒙设备
C:\Users\Administrator》scrcpy -s 192.168.0.10:55555
INFO: scrcpy 1.17 《https://github.com/Genymobile/scrcpy》
C:\ProgramData\chocolatey\lib\scrcpy\tools\scrcpy-server: 1 file pushed, 0 skipped. 1.0 MB/s (34930 bytes in 0.034s)
[server] INFO: Device: HUAWEI TAS-AL00 (Android 10)
INFO: Renderer: direct3d
INFO: Initial texture: 1080x2336
使用鸿蒙专用deveco开发工具连接:运行
WIFI
使用鸿蒙专用deveco开发工具连接:调试
WIFI
结论:鸿蒙系统兼容adb wifi调试,对于想不要约束的开发者,可以使用.
编辑:hfy
