MAX17088 Highly integrated PMI
新品快讯
30人已加入
MAX17088 Highly integrated PMIC provides a cost-effective power solution for notebook LCD panels
Highly integrated PMIC for LCDs includes an I²C-controlled VCOM calibrator.
SUNNYVALE, CA—July 16, 2009—Maxim Integrated Products (NASDAQ: MXIM) announces the MAX17088, a power-management IC (PMIC) that integrates a boost regulator, a programmable VCOM calibrator with nonvolatile memory, a high-current operational amplifier, and a level-shifting scan driver for notebook LCD panels. Developed using Maxim's proprietary high-voltage BiCMOS process, this device includes all functions required to power the LCD source drivers, gate drivers, and VCOM backplane. Through this high level of integration, the MAX17088 provides a cost-effective power solution for LCD panels in notebooks and monitors.
The boost regulator has a 1.2MHz switching frequency and integrates a 20V, 150mΩ power MOSFET. It delivers output voltages up to 18V from a 1.8V to 5.5V input while achieving > 85% efficiency. The integrated operational amplifier drives the VCOM backplane and features ±150mA short-circuit current with a 40V/µs slew rate. The MAX17088 also integrates a scan driver that drives from -25V to +45V and allows output charge sharing to save power. The 2-wire, I²C-controlled VCOM calibrator provides 7-bit setting accuracy and minimizes connector pin count.
The MAX17088 is available in a 6mm x 6mm, 36-pin TQFN package and is fully specified over the -40°C to +85°C extended temperature range. Prices start at $1.25 (1000-up, FOB USA).
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells high-performance semiconductor products. The Company reported revenue in excess of $2 billion for fiscal 2008. Maxim was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products. To date, it has developed over 6000 products serving the industrial, communications, consumer, and computing markets.
