Compact LNA for automotive RKE
新品快讯
30人已加入
Compact LNA for automotive RKE and TPM systems provides optimum performance and current consumption
LNA for RKE or tire pressure monitoring draws a mere 2.5mA of current.
SUNNYVALE, CA—July 23, 2009—Maxim Integrated Products (NASDAQ: MXIM) announces the MAX2634, a low-noise amplifier (LNA) optimized for remote keyless entry (RKE) and tire pressure monitoring (TPM) applications operating in the 315MHz and 433MHz bands. Designed using the Company's SiGe BiCMOS process, this fully integrated LNA improves receiver sensitivity with an ultra-low, 1.25dB noise figure, while consuming a mere 2.5mA (typ) of supply current. The MAX2634 provides superior performance and current consumption in a smaller footprint than both discrete designs and highly integrated CMOS solutions.
The MAX2634 features a logic-enabled shutdown mode that reduces supply current to less than 1µA, thus eliminating the two discrete transistors typically required to implement a shutdown function. Furthermore, this LNA removes the need for external DC-blocking capacitors, enabling a very small solution footprint for today's continually shrinking key-fob designs.
Additionally, the MAX2634 is fully qualified to meet the certification requirements of the AEC-Q100 standard. Customers can design-in the MAX2634 with full confidence that it will withstand the demanding external conditions experienced by automotive designs in the real world.
The MAX2634 operates from a 2.2V to 5.5V supply. Fully specified over the -40°C to +125°C automotive temperature range, it is available in an ultra-small, 2.0mm x 2.2mm, 6-pin SC70 package. Prices start at $0.50 (1000-up, FOB USA). An evaluation kit is available for bench-level evaluation and is priced at $50.00 (each, FOB USA).
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells high-performance semiconductor products. The Company reported revenue in excess of $2 billion for fiscal 2008. Maxim was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products. To date, it has developed over 6000 products serving the industrial, communications, consumer, and computing markets.
  • 相关推荐
  • 热点推荐
  • LNA
