INA220 具有12C接口的双向电流/功率监控器
新品快讯
30人已加入
The INA220 is a current shunt and power monitor with an Two-Wire interface. The INA220 monitors both shunt drop and supply voltage. A programmable calibration value, combined with an internal multiplier, enables direct readouts in amperes. An additional multiplying register calculates power in watts. The Two-Wire interface features 16 programmable addresses. The separate shunt input on the INA220 allows it to be used in systems with low-side sensing.
The INA220 senses across shunts on buses that can vary from 0V to 26V, useful for low-side sensing or CPU power supplies. The device uses a single +3V to +5.5V supply, drawing a maximum of 1mA of supply current. The INA220 operates from -40°C to +125°C.
INA220,pdf datasheet
产品信息
特性
HIGH- or LOW-SIDE SENSING
SENSES BUS VOLTAGES FROM 0V TO +26V
REPORTS CURRENT, VOLTAGE, AND POWER
16 PROGRAMMABLE ADDRESSES
HIGH ACCURACY: 1% (Max) OVER TEMPERATURE
USER PROGRAMMABLE CALIBRATION
FAST (3.4MHz) TWO-WIRE MODE
MSOP-10 PACKAGE
APPLICATIONS
SERVERS
TELECOM EQUIPMENT
NOTEBOOK COMPUTERS
POWER MANAGEMENT
BATTERY CHARGERS
AUTOMOTIVE
POWER SUPPLIES
TEST EQUIPMENT
All trademarks are the property of their respective owners.
产品信息
特性
MSOP-10 PACKAGE
APPLICATIONS
SERVERS
TELECOM EQUIPMENT
NOTEBOOK COMPUTERS
POWER MANAGEMENT
BATTERY CHARGERS
AUTOMOTIVE
POWER SUPPLIES
TEST EQUIPMENT
产品信息
特性
MSOP-10 PACKAGE
APPLICATIONS
SERVERS
TELECOM EQUIPMENT
NOTEBOOK COMPUTERS
POWER MANAGEMENT
BATTERY CHARGERS
AUTOMOTIVE
POWER SUPPLIES
TEST EQUIPMENT
产品信息
特性
MSOP-10 PACKAGE
APPLICATIONS
SERVERS
TELECOM EQUIPMENT
NOTEBOOK COMPUTERS
POWER MANAGEMENT
BATTERY CHARGERS
AUTOMOTIVE
POWER SUPPLIES
TEST EQUIPMENT
  • 相关推荐
  • 热点推荐
