新品快讯
The MAX2164 includes a stand-alone LNA with 1.2dB (typical) noise figure, eliminating the need for an external LNA. The MAX2164 also includes RF variable-gain amplifiers, I and Q downconverting mixers, a baseband variable-gain amplifier, and a low-IF filter. The MAX2164 has monolithic VCOs, a complete frequency synthesizer, and an on-chip crystal oscillator with output buffer. The device operates with a crystal from 32MHz to 36MHz.
The MAX2164 features a 2-wire I2C-compatible serial control interface with multiple addresses for multituner applications. A low-power standby mode is available that shuts down the signal path leaving the control interface, crystal oscillator, and buffer circuits active. An external pin can shut down the entire device.
The MAX2164 is specified for operation in the extended -40°C to +85°C temperature range and is available in a 2.06mm x 2.49mm x 0.35mm, 5 x 6 bump, lead-free WLP package.
关键特性
470MHz to 806MHz Frequency Range | |
1.2dB Noise Figure Integrated Wideband LNA | |
-100dBm to 0dBm High Dynamic Range | |
Integrated VCO and Frequency Synthesizer | |
-93dBc/Hz at 10kHz Low LO Phase Noise | |
Integrated Low-IF Filters | |
Greater Than 40dB Image Rejection | |
Single +2.65V to +3.3V Supply | |
77mW (Typ) Low Power | |
2-Wire I2C Serial-Control Interface | |
Low-Power Shutdown and Standby Modes |
应用/使用
手机移动TV
游戏控制台
家庭音频设备
个人数字助理(PDA)
便携式TV、音频或GPS设备
