ADP1612/ADP1613应用电路(650 kHz /1
新品快讯
30人已加入
ADP1612/ADP1613应用电路(650 kHz /1.3 MHz Step-Up PWM DC-to-DC Switching Converter)
The ADP1612/ADP1613 are step-up dc-to-dc switching converters with an integrated power switch capable of providing an output voltage as high as 20 V. With a package height of less than 1.1 mm, the ADP1612/ADP1613 are optimal for spaceconstrained applications such as portable devices or thin film transistor (TFT) liquid crystal displays (LCDs).
The ADP1612/ADP1613 operate in current mode pulse-width modulation (PWM) with up to 94% efficiency. Adjustable soft start prevents inrush currents when the part is enabled. The pin-selectable switching frequency and PWM current-mode architecture allow for excellent transient response, easy noise filtering, and the use of small, cost-saving external inductors and capacitors. Other key features include undervoltage lockout (UVLO), thermal shutdown (TSD), and logic controlled enable. The ADP1612/ADP1613 are available in the lead-free 8-lead MSOP.
Applications
  • TFT LCD bias supplies
  • Portable applications
  • Industrial/instrumentation equipment
    ADP
  • 打开APP阅读更多精彩内容
    评论(0)
    发评论
    jackhwang 2011-03-23
    0 回复 举报
    这个不就是ADP1612的Data sheet其中一段吗,失望 收起回复
    • 相关推荐
    • 热点推荐
    • ADP
