MAX13055E, MAX13056E, MAX13057
新品快讯
29人已加入
MAX13055E, MAX13056E, MAX13057E, MAX13058E 1.62V to 3.6V, 8-Channel, High-Speed LLT
The MAX13055E–MAX13058E 8-channel, bidirectional level translators provide the level shifting necessary for 100Mbps data transfer in multivoltage systems. The MAX13055E–MAX13058E are ideal for level translation in systems with 8 channels. Externally applied voltages, VCC and VL, set the logic levels on either side of the device. Logic-high signals presented on the VL side of the device appear as a logic-high signal on the VCC side of the device and vice versa.
The MAX13055E–MAX13058E operate at full speed with external drivers that source as little as 4mA output current or larger. Each input/output (I/O) channel is pulled up to VCC or VL by an internal 40µA current source, allowing the MAX13055E–MAX13058E to be driven by either push-pull or open-drain drivers.
The MAX13055E–MAX13058E feature an enable (EN) input to place the device into a low-power shutdown mode when driven low. In addition, the MAX13055E–MAX13058E feature an automatic shutdown mode that disables the part when VCC is less than VL. Each device has a different I/O VL_ and I/O VCC_ state during shutdown mode (see the Ordering Information/Selector Guide in the full data sheet).
The MAX13055E–MAX13058E operate with VCC voltages from +2.2V to +3.6V and VL voltages from +1.62V to +3.2V, making them ideal for data transfer between low-voltage ASIC/PLDs and higher voltage systems. The MAX13055E–MAX13058E are available in 0.4mm pitch, 24-bump WLP and 28-pin TQFN (3.5mm x 5.5mm) packages. The MAX13055E–MAX13058E operate over the extended -40°C to +85°C temperature range.
MAX13055E, MAX13056E, MAX13057E, MAX13058E,pdf datasheet (8-Channel, High-Speed LLT)
  • Compatible with 4mA Input Drivers or Larger
  • 100Mbps Guaranteed Data Rate
  • 8 Bidirectional Channels
  • +1.62V ≤ VL ≤ +3.2V and +2.2V ≤ VCC ≤ +3.6V Supply Voltage Range
  • 24-Bump WLP (0.4mm Pitch) Lead-Free Package
  • 28-Pin TQFN (3.5mm x 5.5mm) Lead-Free Package
  • Extended ESD Protection on I/O VCC Lines
    • ±15kV per Human Body Model
    • ±15kV IEC 61000-4-2 Air Discharge
    • ±8kV IEC 61000-4-2 Contact Discharge
    Camera Modules
     Cell Phones
     GPS
     Low-Voltage ASIC LevelTranslation
     Portable CommunicationDevices
     Portable POS Systems
     Smart Card Readers
     Telecomm Equipment
    LLT
    Typical Operating Circuit
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
    • LLT
