MAX17113 用于LCD TV供电的低成本、多输出电源
新品快讯
30人已加入
The MAX17113 multiple-output power-supply controller generates all the supply rails for thin-film transistor (TFT) liquid-crystal display (LCD) panels in TVs and monitors operating from a regulated 12V input. It includes a step-down and a step-up regulator, a positive and a negative charge pump, a Dual Mode™ logic-controlled high-voltage switch control block, and an adjustable-timing power-good output. The MAX17113 can operate from 8V to 16.5V input voltages and is optimized for LCD TV panel and LCD monitor applications running directly from 12V supplies.
The step-up and step-down regulators feature internal power MOSFETs and high-frequency operation allowing the use of small inductors and capacitors, resulting in a compact solution. Both switching regulators use fixed-frequency current-mode control architectures, providing fast load-transient response and easy compensation. A current-limit function for internal switches and output-fault shutdown protect the step-up and step-down power supplies against fault conditions. The MAX17113 provides soft-start functions to limit inrush current during startup. The MAX17113 provides adjustable power-up timing.
The positive and negative charge-pump regulators provide TFT gate driver supply voltages. Both output voltages can be adjusted with external resistive voltage-dividers. The switch control block allows the manipulation of the positive TFT gate driver voltage.
A series p-channel MOSFET is integrated to sequence power to AVDD after the MAX17113 has proceeded through normal startup, and provides True Shutdown™. The MAX17113 is available in a small (5mm x 5mm), low-profile (0.8mm), 40-pin thin QFN package and operates over a -40°C to +85°C temperature range.
关键特性
  • Optimized for 10.8V to 13.2V Input Supply
  • 8V to 16.5V Input Supply Range
  • Selectable Frequency (450kHz/600kHz)
  • Current-Mode Step-Up Regulator
    • Built-In 20V, 3.3A, 120mΩ n-Channel MOSFET
    • High-Accuracy Output Voltage (1%)
    • True Shutdown
    • Fast Load-Transient Response
    • High Efficiency
    • 10ms Internal Soft-Start
  • Current-Mode Step-Down Regulator
    • Built-In 20V, 3A, 120mΩ n-Channel MOSFET
    • Adjustable Output Voltage Down to 1.5
    • Skip Mode at Light Load
    • High Efficiency
    • 3ms Internal Soft-Start
  • Adjustable Positive and Negative Charge-Pump Regulators
  • Soft-Start and Timer-Delay Fault Latch for All Outputs
  • Logic-Controlled High-Voltage Integrated Switches with Adjustable Delay
  • 180mΩ p-Channel FET for AVDD Sequencing
  • Input Undervoltage Lockout and Thermal- Overload Protection
  • 40-Pin, 5mm x 5mm Thin QFN Package
  • 应用/使用
  • LCD监视器面板表
  • LCD TV板
    • 相关推荐
    • 热点推荐
    • lcd
    • TV
