MAX6010 高精度、微功耗、3V系列电压基准,SOT23
新品快讯
30人已加入
MAX6010 高精度、微功耗、3V系列电压基准,SOT23封装
概述
The MAX6010 is a precision, low-noise, low-dropout, micropower voltage reference in a SOT23 package. This three-terminal voltage reference operates with an input voltage from 3.2V to 5.5V, and outputs 3V.
The MAX6010 voltage reference consumes less than 5µA (max) of supply current and can source up to 7mA and sink up to 1mA of load current when the input is 5V. Unlike conventional shunt-mode (two-terminal) references that waste supply current and require an external resistor, the MAX6010 offers a supply current that is virtually independent of supply voltage (with only 0.05µA/V variation with supply voltage) and does not require an external resistor. The MAX6010 has initial accuracies of 0.2% (A grade) and 0.4% (B grade) and a temperature drift of 50ppm/°C (max). The low-dropout voltage and the ultra-low supply current over the full voltage range make this device ideal for portable and battery-operated applications. The MAX6010 is available in a small, 3-pin SOT23 package.
关键特性
  • Ultra-Low Supply Current: 5µA (max)
  • 3V Output from 3.2V Input
  • Small, 3-Pin SOT23 Package
  • Initial Accuracy: ±0.2% (max)
  • Low Temperature Drift: 50ppm/°C (max)
  • 200mV Dropout Voltage
  • Load Regulation (7mA Source): 200µV/mA (max)
  • Line Regulation 3.2V to 5.5V: 350µV/V (max)
  • 应用/使用
    电池供电设备
     数据采集系统
     工业与过程控制系统
     镜头稳定器
     便携式设备
    电压基
    典型应用电路
