布线技巧与EMC
Inexpensive (Almost Free) Probe/Tweezers for Testing SMD Components
Abstract: Surface-mount test probes can be very expensive, but they are unnecessary for most prototyping uses. A very low-cost set of tweezers/probes for testing surface-mount components can be made in a few minutes. This tool will save time and reduce errors when prototyping with tiny components.
Figure 1. An inexpensive and practical tweezers/probe.
This easy-to-make surface-mount device (SMD) tweezers/probe (Figure 1), is made from scrap PC-board (PCB) material and plugs into a DVM or capacitance/inductance meter for easy measurement of tiny SMD components. (Of course, you still need the appropriate meter.) You will find this tweezers/probe far easier to use with tiny parts than regular DVM probes. It also costs much less than meters that come with the tweezers built in.
Follow these steps to construct your own tweezers/probe.
Figure 2. A diagonal line is scribed down the PCB, but ends about 1/8" from the inside corners.
1. The tweezers are made from 1/16" thick copper-clad PCB material. A single-sided board will do, but a two-sided board was used in this example. Cut a piece to 4" by 3/4" and scribe a diagonal line, not to the corners, but to points about 1/8" from inside the corners on the short edges (Figure 2).
The piece in the above picture was blued to show the line. It helps to have a shear, but you can also cut PCB material by repeatedly scribing a deep groove with a hobby knife and breaking off the board. If you do this, make a groove on both sides of the PCB to get a cleaner edge.
Figure 3. The two cut pieces are set to mirror each other.
2. Cut the board along the diagonal. Use a hobby knife and a metal ruler or other straight-edge guide to cut out copper to make a trace along the long edge of each piece. Orient the cuts to mirror each other. Then also cut two 1/4" by 3/8" copper-clad rectangles for spacers between the two blades (Figure 3).
