MAX17120 三通道高压扫描驱动器,用于TFT LCD
显示光电
97人已加入
The MAX17120 includes three high-voltage level-shifting scan drivers for TFT panel integrated gate logic. Each scan driver has two channels that switch complementarily. The scan-driver outputs swing from +40V to -30V and can swiftly drive capacitive loads. To save power, the scan-driver's complementary outputs share the charge of their capacitive load before they change states.
The MAX17120 is available in a 32-pin, 5mm x 5mm, thin QFN package with a maximum thickness of 0.8mm for ultra-thin LCD panels.
关键特性
  • +40V to -30V Output Swing Range
  • Fast Slew Rate for High Capacitive Load
  • Load Charge Sharing for Power Saving
  • 32-Pin, 5mm x 5mm, Thin QFN Package
  • 应用/使用
     LCD监视器和小型TV板
     笔记本电脑显示器
    • 相关推荐
    • 热点推荐
    • TFT
