MTI Instruments光纤传感器的Fotonic插件模块
今日头条
1194人已加入
MTI Instruments光纤传感器的Fotonic插件模块用于测量频率高达500 kHz的动态边缘位置、位移和振动,Fotonic插件模块用于灵敏的光纤纳米运动和振动测量传感器。
动态边缘位置、位移和振动测量频率可达500 kHz。MTI Instruments独特的光纤探针设计能够适应各种目标反射率或形状,非常适合于各种应用,如超声波喇叭振动或压电材料的研究。
随机光纤分布--随着从探针到目标的距离增大,接收到的光纤按比例捕获更多的光。结果是一个非常敏感的线性输出响应。探针间隙的不断增大将按比例减少接收到的光量,从而产生敏感的线性输出响应,并且具有很大的测量范围和隔离距离。
应用领域
盒式运动
核换热器振动
压电陶瓷,1-3 PZT/聚合物复合材料和PVDF薄膜
压电叠加运动
MTI Instruments是美国精密测试仪器的制造商。其产品需要精确的测量和控制,以及自动化制造、装配和复杂机械操作的开发和实施。MTI Instruments主要用于商用和军用飞机发动机振动定位测试、半导体晶片测试等领域。
深圳市立维创展科技有限公司,优势直接渠道提供MTI Instrument s订货服务,欢迎咨询。
详情了解MTI Instrument s请点击:http://www.ldteq.com/public/brand/70.html
或联系我们的销售工程师:0755-83050846   QQ: 3312069749
P/N Model Measurement Range Stand-Off Resolution Frequency Response
8500-1011 Plug-in Module: MTI-2020R 0.102mm (4mils) – 0.305mm (12mils) 0.127mm (5mils) – 0.508mm (20mils) 0.01µm (1µin) – 0.1µm (1µin) 120kHz
8500-1012 Plug-in Module: MTI-2032R 0.127mm (5mils) – 1.016mm (40mils) 0.127mm (5mils) – 0.889mm (35mils) 0.01µm (1µin) – 0.1µm (1µin) 120kHz
8500-1013 Plug-in Module: MTI-2047R 0.127mm (5mils) – 1.016mm (40mils) 0.127mm (5mils) – 1.118mm (44mils) 0.01µm (1µin) – 0.1µm (1µin) 130kHz
8500-1014 Plug-in Module: MTI-2062R 0.152mm (6mils) – 1.524mm (60mils) 0.127mm (5mils) – 1.778mm (70mils) 0.01µm (1µin) – 0.1µm (1µin) 150kHz
8500-1015 Plug-in Module: MTI-2062H 0.762mm (30mils) – 1.905mm (75mils) 0.762mm (30mils) – 3.81mm (150mils) 0.01µm (1µin) – 0.1µm (1µin) 150kHz
8500-1016 Plug-in Module: MTI-2125R 0.152mm (6mils) – 3.556mm (140mils) 0.178mm (7mils) – 3.048mm (120mils) 0.01µm (1µin) – 0.1µm (1µin) 190kHz
8500-1017 Plug-in Module: MTI-2125H 1.778mm (70mils) – 4.445mm (175mils) 1.27mm (50mils) – 7.62mm (300mils) 0.01µm (1µin) – 0.1µm (1µin) 150kHz
8500-1018 Plug-in Module: MTI-2125CTI 0.508mm (20mils) – 3.556mm (140mils) 0.762mm (30mils) – 5.588mm (220mils) 0.01µm (1µin) – 0.1µm (1µin) 150kHz
8500-1019 Plug-in Module: MTI-2032RX High Resolution 0.036mm (1.4mils) – 4.445mm (175mils) 0.038mm (1.5mils) 0.01µm (1µin) – 0.1µm (1µin) 100kHz
8000-4237 Plug-in Module: MTI-RC200 2.54mm (100mils) 2.54mm (100mils) 0.01µm (1µin) – 0.1µm (1µin) 100kHz
8500-1020 Plug-in Module: MTI-2047E 0.127mm (5mils) – 0.051mm (2mils)     100kHz
8500-1021 Plug-in Module: MTI-2062E 0.191mm (7.5mils) – 0.061mm (2.4mils)     100kHz
责任编辑:haq
