声音信号放大电路
功率放大器电路图
372人已加入
电路能力测试-4:声音信号放大电路
Circuit Knowledge Test-4: Audio Buffer
放大电路
  1. What will be the input and output impedance of QA4 stage with C2412 Hfe=100?
计算QA4的输入及输出阻抗。(假设电晶体的Hfe值为100)
  1. What will be the 6 db lower cut-off frequency and higher cut-off frequency?
计算本电路6 dB的低频及高频截止频率。
  1. What will be the audio buffer gain and maximum undistorted audio output RMS value with 5 volt DC supply?
计算本电路的基本放大倍数,及5V电源时的最大不失真电压值。
  1. Why audio buffer needs only one stage while video buffer needs two stages for amplification?
为何音频电路仅需要单级放大电路,而影像电路必须两级反向。
  1. Calculate the channel cross-talk for this circuit at 100 Hz frequency.
计算本电路在100 Hz时的左右声道串音比。
试题解答
ANS-1:
Input impedance of QA4: 4K7 and 6K8 and 560*100 in parallel.  Actually 2K7.
Output impedance of QA4: 330 Ohm.
ANS-2:
Fl = 1/2ΠRC = 1/ (6.28 * 10u * 2K7) = 6 Hz while R = Input impedance, C = CA24.
Fh = 1/2ΠRC = 1/ (6.28 * 0.033u * 330) = 15 KHz while R = RA43, C = CA26.
ANS-3:
Audio buffer gain: RA43/RA49 = 330/560 = 0.6
Maximum undistorted output: 5.0/2.828 =1.75 Vrms.
ANS-4:
Audio signal is symmetric over dc balance line, while video signal is asymmetric with sync and peak white/black level. One transistor amplifier stage will give out reverse phase signal, then video signal has to reverse back to its original phase. However, audio signal also has to keep L/R channels the same phase.
ANS-5:
Channel cross-talk is caused by amplified signal feeding through dc supply line into the amplifier stage of the other channel.
Impedance of CA45 at 100 Hz: Zc = 1/2ΠFC = 1/(6.28 * 100 * 47u) = 33
Cross-talk rati Zc/RA43 = 0.1 (that is -20 db)
