ADN4604: 4.25 Gbps 16 × 16 Di
新品快讯
30人已加入
ADN4604:  4.25 Gbps 16 × 16 Digital Crosspoint Switch
The ADN4604 is a 16 × 16 asynchronous, protocol agnostic, digital crosspoint switch, with 16 differential PECL/CML-compatible inputs and 16 differential CML outputs.
The ADN4604 is optimized for NRZ signaling with data rates of up to 4.25 Gbps per port. Each port offers a fixed level of input equalization and programmable output swing and output pre-emphasis.
The ADN4604 non-blocking switch core implements a 16 × 16 crossbar and supports independent channel switching through the serial control interface. The ADN4604 has low latency and very low channel-to-channel skew.
An I2C or SPI interface is used to control the device and provide access to advanced features, such as additional levels of pre-emphasis and output disable.
The ADN4604 is packaged in a 16 mm × 16 mm, 100-lead TQFP package and operates from -40°C to +85°C.
特性
  • DC to 4.25 Gbps per port NRZ data rate
  • Programmable receive equalization
  • Programmable transmit pre-emphasis/de-emphasis
  • Low power
    80 mW per channel @ 2.5 V (outputs enabled)
  • 16 × 16, fully differential, non-blocking array
  • DC or AC coupled differential CML inputs
  • 3.3 V core supply
  • Flexible I/O voltage supply range
  • Programmable CML output levels
  • Per-lane input P/N pair inversion for routing ease
  • 50 Ω on-chip I/O termination with programmable on/off capability
  • See data sheet for additional Features
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
    • ADN4604
