ADG1438: ±15 V/+12 V/±5 V, Si
新品快讯
29人已加入
ADG1438:  ±15 V/+12 V/±5 V, Single 8 to 1 Multiplexer, Serially Controlled Matrix Switch
The ADG1438 and ADG1439 are CMOS analog matrix switches with a serially controlled 3-wire interface. The ADG1438 is an 8-channel matrix switch, whereas the ADG1439 is a dual 4-channel matrix switch.
The ADG1438/ADG1439 use a versatile 3-wire serial interface that operates at clock rates of up to 50 MHz and is compatible with standard SPI, QSPI™, MICROWIRE™, and DSP interface standards. The output of the shift register SDO enables a number of the ADG1438/AD1439 parts to be daisy-chained. On power-up, the internal shift register contains all zero, and all switches are in the OFF state.
Each switch conducts equally well in both directions when on, making these parts suitable for both multiplexing and demulti-plexing applications. Because each switch is turned on or off by a separate bit, these parts can also be configured as a type of switch array, where any, all, or none of the eight switches can be closed at any time. The input signal range extends to the supply rails. All channels exhibit break-before-make switching action, preventing momentary shorting when switching channels.
The ultralow on resistance and on resistance flatness of these switches make them ideal solutions for data acquisition and gain switching applications where low distortion is critical. iCMOS™ construction ensures ultralow power dissipation, making the parts ideally suited for portable and battery-powered instruments.
    PRODUCT HIGHLIGHTS
  1. 50 MHz serial interface.
  2. 9.5 Ω on resistance.
  3. 1.6 Ω on resistance flatness.
  4. 3 V logic-compatible digital input, VIH = 2.0 V, VIL = 0.8 V.
    APPLICATIONS
  • Relay replacement
  • Audio and video routing
  • Automatic test equipment
  • Data acquisition systems
  • Temperature measurement systems
  • Avionics
  • Battery-powered systems
  • Communication systems
  • Medical equipment
特性
  • Serial interface; up to 50 MHz
  • SDO daisy-chaining option
  • 9.5 Ω on resistance @ 25°C
  • 1.6 Ω on resistance flatness
  • Fully specified at ±15 V/+12 V/
    ±5 V
  • 3 V logic-compatible inputs
  • Rail-to-rail operation
  • 20-lead TSSOP and 20-lead
    4 mm × 4 mm LFCSP packages
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
    • ADG1438
