MAX14770/MAX14770E 高ESD总线的RS-4
新品快讯
30人已加入
MAX14770/MAX14770E 高静电现场总线的RS-485收发器
概述
The MAX14770E is a half-duplex, ±35kV HBM high ESD-protected transceiver for Profibus-DP® and RS-485 applications. In addition, it can be used for RS-422/V.11 communications. The MAX14770E is designed to meet IEC 61158-2, TIA/EIA-422-B, TIA/EIA-485-A, V.11, and X.27 standards.
The MAX14770E operates from a +5V supply and has true fail-safe circuitry that guarantees a logic-high receiver output when the receiver inputs are open or shorted.
The MAX14770E features a 1/4 standard-unit load receiver input impedance, allowing up to 128 1/4 unit load transceivers on the bus. Drivers are short-circuit current limited and are protected against excessive power dissipation by thermal-shutdown circuitry.
The MAX14770E is available in 8-pin SO and tiny TDFN (3mm x 3mm) packages, and is specified over the extended (-40°C to +85°C) and automotive (-40°C to +125°C) temperature ranges.
关键特性
  • Meets EIA 61158-2 Type 3 Profibus-DP
  • +4.5V to +5.5V Supply Voltage
  • 20Mbps Data Rate
  • Short-Circuit Protected
  • True Fail-Safe Receiver
  • Thermal-Shutdown Protected
  • Hot Swappable
  • High ESD Protection
    • ±35kV Human Body Model (HBM)
    • ±20kV IEC 61000-4-2 Air Gap
    • ±10kV IEC 61000-4-2 Contact
  • -40°C to +125°C Automotive Temperature Range in Tiny 8-Pin (3mm x 3mm) TDFN
    应用/使用
    工业向场总线
  • 机械编码器
  • 运动控制器
  • Profibus-DP网络
  • RS-485网络
    MAX147
    功能框图
  • 打开APP阅读更多精彩内容
