MAXQ314 单相交流电源测量IC,带有I²C接
新品快讯
30人已加入
MAXQ314 单相交流电源测量IC,带有I²C接口
The MAXQ314 performs voltage and current measurements using an integrated ADC that can measure voltage and current. Other values such as power are calculated from that data. The MAXQ314 also has an integrated temperature sensor that provides the die temperature on demand. The internal current amplifier produces up to 32x gain and the voltage amplifier gain is 1x.
关键特性
  • High-Performance, Low-Power DSP Core
  • On-Chip Digital Temperature Sensor
  • Precision Internal Voltage Reference
  • Active Power (W), < ±0.5% Error
  • Reactive Power (VAR), < ±0.7% Error
  • Apparent Power (VA), < ±0.7% Error
  • Power Factor, < ±1% Error
  • Voltage RMS, < ±0.2% Error
  • Current RMS, < ±0.5% Error
  • I²C-Compatible Serial Interface
  • Continuous Output of IRMS in Serial or PWM
  • 应用/使用
  • 单相交流电源监测
    单相交流
    原理框图
