新品快讯
MAX4969 PCIe、单通道、2:1/1:2复用器和接收器,具有均衡功能
The MAX4969 active 2:1 and 1:2 multiplexer equalizes and redrives PCIe® signals up to 5.0GT/s (Gigatransfers per second) and operates from a single +3.3V supply.
The MAX4969 features PCIe-required electrical idle and receiver detection on each channel and improves signal integrity at the receiver through independent programmable input equalization and output deemphasis.
The MAX4969 is available in a small, 42-pin (3.5mm x 9.0mm) TQFN package optimal for simplified layout and space-saving requirements. The MAX4969 is specified over the 0°C to +70°C commercial operating temperature range.
关键特性
应用/使用
| 刀片式服务器 | |
| Communications Switches | |
| 存储局域网 | |
| 测试设备 | |
| 工作站 |
