MAX4885AE 宽带、VGA 2:1开关,具有±15kV
新品快讯
29人已加入
MAX4885AE 宽带、VGA 2:1开关,具有±15kV ESD保护
概述
The MAX4885AE integrates high-bandwidth analog switches, level-translating buffers, and level-translating FET switches to implement a complete 2:1 multiplexer for VGA signals. The device provides three very high-frequency 900MHz (typ) SPDT switches for RGB signals, two low-frequency clamping switches for the DDC signals, a pair of level-translating buffers for the H and V signals and integrated extended ESD protection.
Horizontal and vertical synchronization (H_/V_) inputs feature level-shifting buffers to support low-voltage controllers and standard 5V-TTL-compatible monitors, meeting the VESA requirement. Display Data Channel (DDC), consisting of SDA_ and SCL_, are FET switches that protect the low-voltage VGA source from potential damage from high-voltage presence on the monitor while reducing capacitive load.
All seven output terminals of the MAX4885AE feature high-ESD protection to ±15kV Human Body Model (HBM) (see the Pin Description in the full data sheet). All other pins are protected to ±2kV Human Body Model (HBM).
The MAX4885AE is specified over the extended -40°C to +85°C temperature range, and is available in a space-saving, 28-pin, 4mm × 4mm TQFN package.
关键特性
  • Low 5Ω (typ) On-Resistance (R, G, B Signals)
  • Low 5.5pF (typ) On-Capacitance (R, G, B Signals)
  • Independent, Selectable Logic Inputs for Switching
  • Similar Pin Configuration to MAX4885
  • Ultra-Small, 28-Pin (4mm x 4mm) TQFN Package
  • ±15kV ESD Human Body Model (HBM)
    应用/使用
    服务器KVM
  • Notebook Computers—MXM/Switchable Graphics
    ESD保护
    典型工作电路
  • 打开APP阅读更多精彩内容
