freemodbus教程之freemodbus移植应用串口中断接收和数据解析
接口/总线/驱动
52人已加入
本篇主要讲解从机数据的接收流程。接收流程分为两个阶段:串口中断接收和数据解析。
第一阶段:中断接收函数prvvUARTRxISR(xMBRTUReceiveFSM)和定时器中断回调函数xMBRTUtimerT35Expired(),
第二阶段:数据解析eMBPoll(  )。
一、串口中断接收
  从机正常状态下,串口设置为接收中断模式,也不启动定时器。当检测到有数据时,中断函数调用xMBRTUReceiveFSM()函数,通过该函数中的ucRTUBuf数组存储接收帧,用usRcvBufferPos存储数据帧长度。具体函数:
1、中断接收函数。
void UART1_IRQ(void)
    IF(USART_GetITStatus(USART1,USART_IT_TXE))
        pxMBFrameCBTransmitterEmpty(  );
    else if(USART_GetITStatus(USART1,USART_IT_RXNE))//接收中断
        pxMBFrameCBByteReceived(  );//pxMBFrameCBByteReceived = xMBRTUReceiveFSM;
2、xMBRTUReceiveFSM()函数。RTU接收状态函数。只要进人该函数,就会启动定时器中断。
  从机的接收状态:
     (1)STATE_RX_INIT(协议栈初始化);
(2)STATE_RX_ERROR(接收错误);
(3)STATE_RX_IDLE(接收空闲,接收帧头,常用);
(4)STATE_RX_RCV(接收所有数据,常用)。
  注意:接收数据时,只要接收到数据,定时器就会清零,重新计数
BOOL
xMBRTUReceiveFSM( void )
    BOOL            xTaskNeedSwitch = FALSE;
    UCHAR           ucByte;
    assert( eSndState == STATE_TX_IDLE );
    /* Always read the character. */
    ( void )xMBPortSerialGetByte( ( CHAR * ) & ucByte );
    switch ( eRcvState )
        /* If we have received a character in the init state we have to
         * wait until the frame is finished.
    case STATE_RX_INIT:
        vMBPortTimersEnable(  );
        break;
        /* In the error state we wait until all characters in the
         * damaged frame are transmitted.
    case STATE_RX_ERROR:
        break;
        /* In the idle state we wait for a new character. If a character
         * is received the t1.5 and t3.5 timers are started and the
         * receiver is in the state STATE_RX_RECEIVCE.
    case STATE_RX_IDLE:
        usRcvBufferPos = 0;
        ucRTUBuf[usRcvBufferPos++] = ucByte;
        eRcvState = STATE_RX_RCV;
        /* Enable t3.5 timers. */
        break;
        /* We are currently receiving a frame. Reset the timer after
         * every character received. If more than the maximum possible
         * number of bytes in a modbus frame is received the frame is
         * ignored.
    case STATE_RX_RCV:
        if( usRcvBufferPos < MB_SER_PDU_SIZE_MAX )
        else
            eRcvState = STATE_RX_ERROR;
        break;
    return xTaskNeedSwitch;
二、数据解析
涉及到的函数 eMBPoll、eMBRTUReceive和xFuncHandlers[i]是结构体数组。
1、eMBPoll函数。eMBPoll函数调用eMBRTUReceive和xFuncHandlers[i]结构体数组。
eMBErrorCode
eMBPoll( void )
    static UCHAR   *ucMBFrame;
    static UCHAR    ucRcvAddress;
    static UCHAR    ucFunctionCode;
    static USHORT   usLength;
    static eMBException eException;
    int             i;
    eMBErrorCode    eStatus = MB_ENOERR;
    eMBEventType    eEvent;
    /* Check if the protocol stack is ready. */
    if( eMBState != STATE_ENABLED )
        return MB_EILLSTATE;
    /* Check if there is a event available. If not return control to caller.
     * Otherwise we will handle the event. */
    if( xMBPortEventGet( &eEvent ) == TRUE )
        switch ( eEvent )
        case EV_READY:
            break;
        case EV_FRAME_RECEIVED:
            eStatus = peMBFrameReceiveCur( &ucRcvAddress, &ucMBFrame, &usLength );
            if( eStatus == MB_ENOERR )
                /* Check if the frame is for us. If not ignore the frame. */
                if( ( ucRcvAddress == ucMBAddress ) || ( ucRcvAddress == MB_ADDRESS_BROADCAST ) )
                    ( void )xMBPortEventPost( EV_EXECUTE );
            break;
        case EV_EXECUTE:
            ucFunctionCode = ucMBFrame[MB_PDU_FUNC_OFF];//把接收的数据传递给ucFunctionCode
            eException = MB_EX_ILLEGAL_FUNCTION;
            for( i = 0; i < MB_FUNC_HANDLERS_MAX; i++ )
                /* No more function handlers registered. Abort. */
                if( xFuncHandlers[i].ucFunctionCode == 0 )
                    break;
                else if( xFuncHandlers[i].ucFunctionCode == ucFunctionCode )//查询匹配的功能码,
                    eException = xFuncHandlers[i].pxHandler( ucMBFrame, &usLength );//调用相应的功能函数
                    break;
            /* If the request was not sent to the broadcast address we
             * return a reply. */
            if( ucRcvAddress != MB_ADDRESS_BROADCAST )
                if( eException != MB_EX_NONE )//如果接收有问题
                    /* An exception occured. Build an error frame. */
                    usLength = 0;
                    ucMBFrame[usLength++] = ( UCHAR )( ucFunctionCode | MB_FUNC_ERROR );//功能码与0x80或之后的为        //异常码
                    ucMBFrame[usLength++] = eException;//非法功能代码
                if( ( eMBCurrentMode == MB_ASCII ) && MB_ASCII_TIMEOUT_WAIT_BEFORE_SEND_MS )
                    vMBPortTimersDelay( MB_ASCII_TIMEOUT_WAIT_BEFORE_SEND_MS );
                eStatus = peMBFrameSendCur( ucMBAddress, ucMBFrame, usLength );//发送数据
            break;
        case EV_FRAME_SENT:
            break;
    return MB_ENOERR;
2、peMBFrameReceiveCur() //数据帧接收函数指针
3、主要讲一下xFuncHandlers[i],它是结构体数组,存放的是功能码以及对应的报文解析函数。
typedef struct { UCHAR ucFunctionCode; pxMBFunctionHandler pxHandler; } xMBFunctionHandler;
static xMBFunctionHandler xFuncHandlers[MB_FUNC_HANDLERS_MAX] = {
#if MB_FUNC_OTHER_REP_SLAVEID_ENABLED > 0
    {MB_FUNC_OTHER_REPORT_SLAVEID, eMBFuncReportSlaveID},
#endif
#if MB_FUNC_READ_INPUT_ENABLED > 0
    {MB_FUNC_READ_INPUT_REGISTER, eMBFuncReadInputRegister},
#endif
#if MB_FUNC_READ_HOLDING_ENABLED > 0
    {MB_FUNC_READ_HOLDING_REGISTER, eMBFuncReadHoldingRegister},
#endif
#if MB_FUNC_WRITE_MULTIPLE_HOLDING_ENABLED > 0
    {MB_FUNC_WRITE_MULTIPLE_REGISTERS, eMBFuncWriteMultipleHoldingRegister},
#endif
#if MB_FUNC_WRITE_HOLDING_ENABLED > 0
    {MB_FUNC_WRITE_REGISTER, eMBFuncWriteHoldingRegister},
#endif
#if MB_FUNC_READWRITE_HOLDING_ENABLED > 0
    {MB_FUNC_READWRITE_MULTIPLE_REGISTERS, eMBFuncReadWriteMultipleHoldingRegister},
#endif
#if MB_FUNC_READ_COILS_ENABLED > 0
    {MB_FUNC_READ_COILS, eMBFuncReadCoils},
#endif
#if MB_FUNC_WRITE_COIL_ENABLED > 0
    {MB_FUNC_WRITE_SINGLE_COIL, eMBFuncWriteCoil},
#endif
#if MB_FUNC_WRITE_MULTIPLE_COILS_ENABLED > 0
    {MB_FUNC_WRITE_MULTIPLE_COILS, eMBFuncWriteMultipleCoils},
#endif
#if MB_FUNC_READ_DISCRETE_INPUTS_ENABLED > 0
    {MB_FUNC_READ_DISCRETE_INPUTS, eMBFuncReadDiscreteInputs},
#endif
 以功能码04为例,读取输入寄存器。
eMBException
eMBFuncReadInputRegister( UCHAR * pucFrame, USHORT * usLen )
    USHORT          usRegAddress;
    USHORT          usRegCount;
    UCHAR          *pucFrameCur;
    eMBException    eStatus = MB_EX_NONE;
    eMBErrorCode    eRegStatus;
    if( *usLen == ( MB_PDU_FUNC_READ_SIZE + MB_PDU_SIZE_MIN ) )//计算帧长度,除了地址位和两位的crc校验
        usRegAddress = ( USHORT )( pucFrame[MB_PDU_FUNC_READ_ADDR_OFF] << 8 );//读取寄存器的首地址
        usRegAddress |= ( USHORT )( pucFrame[MB_PDU_FUNC_READ_ADDR_OFF + 1] );
        usRegAddress++;
        usRegCount = ( USHORT )( pucFrame[MB_PDU_FUNC_READ_REGCNT_OFF] << 8 );//计算读取寄存器的长度
        usRegCount |= ( USHORT )( pucFrame[MB_PDU_FUNC_READ_REGCNT_OFF + 1] );
        /* Check if the number of registers to read is valid. If not
         * return Modbus illegal data value exception.
        if( ( usRegCount >= 1 )
            && ( usRegCount < MB_PDU_FUNC_READ_REGCNT_MAX ) )//读取寄存器的长度不越界
            /* Set the current PDU data pointer to the beginning. */
            pucFrameCur = &pucFrame[MB_PDU_FUNC_OFF];//把数据帧赋值给pucFrameCur
            *usLen = MB_PDU_FUNC_OFF;
            /* First byte contains the function code. */
            *pucFrameCur++ = MB_FUNC_READ_INPUT_REGISTER;//
            *usLen += 1;
            /* Second byte in the response contain the number of bytes. */
            *pucFrameCur++ = ( UCHAR )( usRegCount * 2 );
            *usLen += 1;
            eRegStatus =
                eMBRegInputCB( pucFrameCur, usRegAddress, usRegCount );
            /* If an error occured convert it into a Modbus exception. */
            if( eRegStatus != MB_ENOERR )
                eStatus = prveMBError2Exception( eRegStatus );
            else
                *usLen += usRegCount * 2;
        else
            eStatus = MB_EX_ILLEGAL_DATA_VALUE;
    else
        /* Can't be a valid read input register request because the length
         * is incorrect. */
    return eStatus;
eMBErrorCode
eMBRegInputCB( UCHAR * pucRegBuffer, USHORT usAddress, USHORT usNRegs )
    int             iRegIndex;
    if( ( usAddress >= REG_INPUT_START )
        && ( usAddress + usNRegs <= REG_INPUT_START + REG_INPUT_NREGS ) )
        iRegIndex = ( int )( usAddress - REG_INPUT_START );
        while( usNRegs > 0 )
            *pucRegBuffer++ =
                ( unsigned char )( usRegInputBuf[iRegIndex] >> 8 );
            *pucRegBuffer++ =
                ( unsigned char )( usRegInputBuf[iRegIndex] & 0xFF );
            iRegIndex++;
            usNRegs--;
    else
        eStatus = MB_ENOREG;
    return eStatus;
以上就是整个接收数据、解析数据的过程。
来源:csdn博客 萧年已逝;在此特别鸣谢!
