MAX97000 具有单声道D类扬声器放大器和H类耳机放大器的音频子系统
概述
The
MAX97000 audio subsystem combines a mono speaker amplifier with a stereo headphone amplifier and an analog DPST switch. The headphone and speaker amplifiers have independent volume control and on/off control. The 4 inputs are configurable as 2 differential inputs or 4 single-ended inputs.
The entire subsystem is designed for maximum efficiency. The high-efficiency 725mW Class D speaker amplifier operates directly from the battery and consumes no more than 1µA in shutdown mode. The Class H headphone amplifier utilizes a dual mode charge pump to maximize efficiency while outputting a ground referenced signal that does not require output coupling capacitors.
The speaker amplifier incorporates a distortion limiter to automatically reduce the volume level when excessive clipping occurs. This allows high gain for low-levels signals without compromising the quality of large signals.
All control is performed using the 2-wire, I
2C interface. The MAX97000 operate in the extended -40°C to +85°C temperature range, and is available in the 2mm x 2mm, 25-bump WLP package (0.4mm pitch).
关键特性
| 2.7V to 5.5V Single Supply Voltage |
725mW Speaker Output (VPVDD = 3.7V, ZSPK = 8Ω + 68µH) |
40mW/Channel Headphone Output (RHP = 16Ω) |
Low-Emission Class D Amplifier |
Efficient Class H Headphone Amplifier |
Ground Referenced Headphone Outputs |
2 Stereo Single-Ended/Mono Differential Inputs |
Integrated Distortion Limiter (Speaker Outputs) |
Integrated DPST Analog Switch |
No Clicks and Pops |
TDMA Noise Free |
2mm x 2mm, 25-Bump 0.4mm Pitch WLP Package |
应用/使用
蜂窝电话
便携式多媒体播放器
