MAX16068 6通道、闪存可配置系统管理器,提供非易失故
新品快讯
29人已加入
MAX16068 6通道、闪存可配置系统管理器,提供非易失故障寄存器
概述
The MAX16068 flash-configurable system manager monitors and manages up to six system voltages simultaneously. The MAX16068 integrates an analog-to-digital converter (ADC). Device configuration information, including overvoltage and undervoltage limits, time delay settings is stored in nonvolatile flash memory. During a fault condition, fault flags and channel voltages can be automatically stored in the nonvolatile flash memory for later read-back.
The internal 1% accurate, 10-bit ADC measures each input and compares the result to one overvoltage and one undervoltage limit. A fault signal asserts when a monitored voltage falls outside the set limits.
The MAX16068 supports a power-supply voltage of up to 14V and can be powered directly from the 12V intermediate bus in many systems.
The MAX16068 includes six programmable general-purpose inputs/outputs (GPIOs). GPIOs are flash configurable as a fault output, as a watchdog input or output, or as a manual reset.
The MAX16068 features nonvolatile fault memory for recording information during system shutdown events. The fault logger records a failure in the internal flash and sets a lock bit protecting the stored fault data from accidental erasure.
An SMBus™ or a JTAG serial interface configures the MAX16068. The MAX16068 is available in a 28-pin, 5mm × 5mm, TQFN package and is fully specified over the -40°C to +85°C extended temperature range.
关键特性
  • Operates from 2.8V to 14V
  • 1% Accurate, 10-Bit ADC Monitors 6 Voltage Inputs
  • Analog EN Monitoring Input
  • 6 Monitored Inputs with Overvoltage and Undervoltage Limits
  • Nonvolatile Fault Event Logger
  • Six General-Purpose Inputs/Outputs Configurable as:
    • Dedicated Fault Output
    • Watchdog Timer Function
    • Manual Reset
    • SMBus Alert
    • Fault Propagation Input/Output
  • SMBus and JTAG Interface
  • Supports Cascading with MAX16065/MAX16066
  • Flash-Configurable Time Delays and Thresholds
  • -40°C to +85°C Extended Operating Temperature Range
应用/使用
网络设备
 服务器
 存储/RAID系统
 电信设备(基站、接入)
MAX1616
Typical Operating Circuit
