AD7171: 16-Bit Low Power ΣW
新品快讯
30人已加入
AD7171:  16-Bit Low Power Σ−Δ ADC
The AD7171 is a very low power 16-bit analog-to-digital converter (ADC). It contains a precision 16-bit Σ-Δ ADC and an on-chip oscillator. Consuming only 110 μA, the AD7171 is particularly suitable for portable or battery operated products where very low power is a requirement. The AD7171 also has a power down mode in which the device consumes 5 μA, thus increasing the battery life of the product.
For ease-of-use, all the features of the AD7171 are controlled by dedicated pins. Each time a data read occurs, 8 status bits are appended to the 16-bit conversion. These status bits contain a pattern sequence that can be used to confirm the validity of the serial transfer.
The output data rate of the AD7171 is 125 Hz while the settling time is 24 ms. The AD7171 has one differential input and has a gain of 1. This is useful in applications where the user needs to use an external amplifier to implement system-specific filtering or gain requirements.
The AD7171 operates with a power supply from 2.7 V to 5.25 V. It is available in a 10-lead LFCSP packa
特性
  • Output data rate: 125 Hz
  • RMS Noise: 6.9 μV
  • Pin-Programmable powerdown and reset
  • Status Function
  • Internal clock oscillator
  • Current: 110 μA
  • Power supply: 2.7 V to 5.25 V
  • –40°C to +105°C temperature range
  • 3 mm x 3 mm LFCSP package
    AD7171
    • 相关推荐
    • 热点推荐
    • AD7171
