AD5512A: 2.7 V to 5.5 V, Seri
新品快讯
29人已加入
AD5512A:  2.7 V to 5.5 V, Serial-Input, Voltage-Output
The AD5541A/AD5542A/AD5512A are single, 16-/16-/12-bit, serial input, unbuffered voltage output digital-to-analog converters (DACs) that operate from a single 2.7 V to 5.5 V supply. The AD5541A/AD5542A/AD5512A utilize a versatile 3-wire interface that is compatible with a 50 MHz SPI, QSPI™, MICROWIRE™, and DSP interface standards. These DACs provide 16-/12-bit performance without any adjustments. The DAC output is unbuffered, which reduces power consumption and offset errors contributed to by an output buffer. The AD5542A/AD5512A can be operated in bipolar mode, which generates a ±VREF output swing. The AD5542A/AD5512A also includes Kelvin sense connections for the reference and analog ground pins to reduce layout sensitivity.
The AD5541A is available in 10-lead 3 mm × 3 mm LFCSP and 10-lead MSSOP. The AD5541A-1 is available in 8-lead 3 mm × 3 mm LFCSP. The AD5542A/AD5512A are available in 16-lead 3 mm × 3 mm LFCSP and the AD5542A is also available in 16-lead TSSOP. The AD5542A-1 is available in 10-lead LFCSP. The AD5541A and AD5542A are specified over a temperature range of −40°C to 105°C.
Applications
  • Automatic test equipment
  • Precision Source-measure Instruments
  • Data Acquisition Systems
  • Medical Instrumentation
  • Aerospace Instrumentation
  • Communications Infrastructure equipment
  • Industrial Control
特性
  • Low power, 1 LSB INL nanoDAC™
  • AD5541A: 16 bits
    AD5542A: 16 bits
    AD5512A: 12 bits
  • 2.7 V to 5.5 V single-supply operation
  • Low glitch: 0.5 nV-s
  • Unbuffered voltage output capable of driving 60 kΩ loads directly
  • VLOGIC pin provides 1.8 V digital interface capability
  • Hardware CLR and LDAC functions
  • 50 MHz SPI-/QSPI-/MICROWIRE-/DSP-compatible interface standards
  • Power-on reset clears DAC output to zeroscale and midscale
  • Available in 3 mm × 3 mm 16-LFCSP
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
    • AD5512A
