欧盟发布“量值继电器和保护设备”等9项标准
电容器
230人已加入
欧盟09年10月下旬发布的电工标准目录
标准号
英文题目
中文题目
技术机构
发布日期
适用指令
EN 50215:2009
Railway applications - Rolling stock - Testing of rolling stock on completion of construction and before entry into service
铁路应用---运输工具---结构完成和进入服务前的运输工具
CLC/SC 9XB
2009-10-30
EN 50397-2:2009
Covered conductors for overhead lines and the related accessories for rated voltages above 1 kV AC and not exceeding 36 kV AC -- Part 2: Accessories for covered conductors - Tests and acceptance criteria
≥1 kV AC 和≤ 36 kV AC时的过热线和相关组件的覆盖导线---第2部分:覆盖导线组件---试验和接收判据
CLC/TC 20
2009-10-30
EN 60255-26:2009
Measuring relays and protection equipment -- Part 26: Electromagnetic compatibility requirements
量值继电器和保护设备---第26部分:电磁兼容性要求
CLC/SR 95
2009-10-29
2004/108/EC
EN 60255-151:2009
Measuring relays and protection equipment -- Part 151: Functional requirements for over/under current protection
量值继电器和保护设备---第151部分:过电流或非电流保护的功能要求
CLC/SR 95
2009-10-23
EN 61003-2:2009
Industrial-process control systems - Instruments with analogue inputs and two- or multi-state outputs -- Part 2: Guidance for inspection and routine testing
工业过程控制系统---模拟输入和两路或多路输出仪---第2部分:检验和常规试验
CLC/SR 65B
2009-10-23
EN 62087:2009
Methods of measurement for the power consumption of audio, video and related equipment
音频、视频和有关设备的功率消耗测量方法
CLC/TC 206
2009-10-22
EN 62423:2009
Type B residual current operated circuit-breakers with and without integral overcurrent protection for household and similar uses (Type B RCCBs and Type B RCBOs)
B 类家用和类似用途的不带过电流保护的剩余电流动作断路器(B类 RCCBs和 B类 RCBO)
CLC/TC 23E
2009-10-22
2004/108/EC, 2006/95/EC
EN 61029-2-9:2009
Safety of transportable motor-operated electric tools -- Part 2-9: Particular requirements for mitre saws
移动式电动机床的安全---第2-9部分: 斜面锯机专门要求
CLC/TC 116
2009-10-21
98/37/EC, 2006/42/EC
EN 61029-2-11:2009
Safety of transportable motor-operated electric tools -- Part 2-11: Particular requirements for combined mitre and bench saws
移动式电动机床的安全---第2-4部分:斜面锯和台锯组合机械专门要求
CLC/TC 116
2009-10-21
