MAX15041 Low-cost, synchronous
新品快讯
30人已加入
MAX15041 Low-cost, synchronous DC-DC regulator delivers up to 3A in a 3mm x 3mm package
DC-DC regulator with 3A output current saves space and cost.
Maxim's new buck regulator integrates two power switches in its compact TQFN to save space, reduce EMI, and simplify design.
SUNNYVALE, CA—December 16, 2009—Maxim Integrated Products (NASDAQ: MXIM) introduces the MAX15041, a synchronous DC-DC converter with integrated MOSFETs in a small 3mm x 3mm package. The built-in MOSFETs offer higher efficiency (93%) than asynchronous solutions, while simplifying design and minimizing EMI. Capable of delivering up to 3A, the MAX15041 is ideally suited for a variety of point-of-load applications including telecom and networking equipment, as well as low-cost consumer products.
This device operates from a fixed 350kHz PWM frequency and utilizes a peak-current-mode architecture to simplify compensation. This topology ensures excellent load transient response, thus enabling an all-ceramic-capacitor design. Other features include an enable input and power-good indicator. This converter also offers the ability to safely start up into a prebiased output.
The MAX15041 operates from a 4.5V to 28V input voltage and provides ±1% output-voltage accuracy over temperature. Available in a space-saving, 3mm x 3mm, 16-pin TQFN package, the device is fully specified over the -40°C to +85°C extended temperature range. Prices start at $1.80 (1000-up, FOB USA).
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells high-performance semiconductor products. The Company was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products. To date, it has developed over 6200 products serving the industrial, communications, consumer, and computing markets.
