MAXQ3181 低功耗、有功功率测量、多相AFE (应用电
新品快讯
29人已加入
MAXQ3181 低功耗、有功功率测量、多相AFE (应用电路)
概述
The MAXQ3181 is a dedicated electricity measurement front-end that collects and calculates polyphase voltage, current, active power and energy, and many other metering parameters of a polyphase load. The computed results can be retrieved by an external master through the on-chip serial peripheral interface (SPI™) bus. This bus is also used by the external master to configure the operation of the MAXQ3181 and monitor the status of operations.
The MAXQ3181 performs voltage and current measurements using an integrated ADC that can measure up to seven external differential signal pairs. An eighth differential signal pair is used to measure the die temperature. An internal amplifier automatically adjusts the current channel gain to compensate for low-current channel-signal levels.
关键特性
  • Compatible with 3-Phase/3-Wire, 3-Phase/4-Wire, and Other 3-Phase Services
  • 0.1% Active Power and Energy Linearity Error
  • 0.5% Apparent Power and Energy Linearity Error
  • 0.5% Linearity Errors for RMS Voltage and RMS Current
  • Neutral Line Current Measurement
  • Line Frequency (Hz)
  • Power Factors
  • Phase Sequence Indication
  • Phase Voltage Absence Detection
  • Programmable Pulse Width
  • Programmable No-Load Current Threshold
  • Programmable Meter Constant
  • Programmable Thresholds for Undervoltage and Overvoltage Detection
  • Programmable Threshold for Overcurrent Detection
  • Amp-Hours in Absence of Voltage Signals
  • On-Chip Digital Temperature Sensor
  • Precision Internal Voltage Reference 2.048V 30ppm/°C typical), Also Supports An External Voltage Reference
  • Active Power and Energy of Each Phase and Combined 3-Phase (kWh), Positive and Negative
  • Apparent Power and Energy of Each Phase and Combined 3-Phase
  • Supports Software Meter Calibration
  • Up to 3-Point Multipoint Calibration to Compensate for Transducer Nonlinearity
  • Power-Fail Detection
  • Bidirectional Reset Input/Output
  • SPI-Compatible Serial Interface with Interrupt Request (Acitve-Low IRQ) Output
  • Single 3.3V Supply, Low Power (35mW typical)
    应用/使用
    3相有功功率电表
    AFE
    典型应用电路
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
    • AFE
