MAX9376 LVDS/任意逻辑至LVPECL/LVDS、双路电平转换器
概述
The MAX9376 is a fully differential, high-speed, LVDS/anything-to-LVPECL/LVDS dual translator designed for signal rates up to 2GHz. One channel is LVDS/anything-to-LVPECL translator and the other channel is LVDS/anything-to-LVDS translator. The MAX9376's extremely low propagation delay and high speed make it ideal for various high-speed network routing and backplane applications.
The
MAX9376 accepts any differential input signal within the supply rails and with minimum amplitude of 100mV. Inputs are fully compatible with the LVDS, LVPECL, HSTL, and CML differential signaling standards. LVPECL outputs have sufficient current to drive 50Ω transmission lines. LVDS outputs conform to the ANSI EIA/TIA-644 LVDS standard.
The MAX9376 is available in a 10-pin µMAX® package and operates from a single +3.3V supply over the -40°C to +85°C temperature range.
关键特性
Guaranteed 2GHz Switching Frequency
Accepts LVDS/LVPECL/Anything Inputs
421ps (typ) Propagation Delays
30ps (max) Pulse Skew
2psRMS (max) Random Jitter
Minimum 100mV Differential Input to Guarantee AC Specifications
Temperature-Compensated LVPECL Output
+3.0V to +3.6V Power-Supply Operating Range
> 2kV ESD Protection (Human Body Model)
应用/使用
背板逻辑标准转换
DLC
DSLAM背板
局域网(LAN)
LVDS至LVPECL、LVPECL至LVDS转换
上/下变频器
WAN
引脚配置
