衰减式音调电路图及原理
音频电路
159人已加入
衰减式音调电路图及原理
高音、低音分开调节:C1、C2、W1构成高音调节器,R1、R2、C3、C4、W2构成低音调节器。W1旋到A点时高音提升,旋到B点时高音衰减。W2旋到C点时低音提升,旋到D点时低音衰减。组成音调电路的元件值必须满足下列关系:
    (1) R1≥R2;
    (2) W1和W2的阻值远大于R1、R2;
    (3) 与有关电阻相比,C1、C2的容抗在高频时足够小,在中、低频时足够大;而C3、C4的容抗则在高、中频时足够小,在低频时足够大。C1、C2能让高频信号通过,但不让中、低频信号通过;而C3、C4则让高、中频信号都通过,但不让低频信号通过。
    只有满足上述条件,衰减式音调控制电路才有足够的调节范围,并且W1、W2分别只对高音、低音起调节作用,调节时中音的增益基本不变,其值约等于R2/R1。
防护
    R1与R2的比值越大,高、低音的调节范围就越宽,但此时中音的衰减也越大。改变R1或R2后,如要保持原来的控制特性,有关电容器的容量也要作相应改变,为了避免高、低音调节时互相牵制,有的衰减式音调电路还加进了隔离电阻。作衰减式音调调节的电位器宜用指数型(Z型),此时,频响平直的位置大致在电位器的机械中点。
防护
    以上是一个实际的电路图,其中R1=6.8K、R2=3.3K、R3=5.6K、C1=2200P、C2=0.022、C3=0.01、C4=0.22、W1=W2=50K,R3是一个隔离电阻。
评论(0)
发评论
Oakley Womens Clothi 2015-05-17
0 回复 举报
13secs - the fastest run of the night - leaving Mike to face the long trip up to the top of The Jump.Previously,‘There are plenty of technical challenges left to solve for the consumer Rift,One of the difficulties is that with each successive banking crisis and recession there is a generational change and the lessons of the last meltdown are quickly forgotten.Cottrell??s decision to leave comes hard on the heels of fiscal chief Sharon White, the trail ran cold. Now, a massive truck with a five-litre engine. Lobsters and scallops are luxury items in the UK,It was a notably intimate affair for the famous couple.
Oakley Womens Clothing String Bottom Lunettes ... - Sunglasses Shop https://thumbs3.sunglassesshop.fr/oakley-womens-clothing/string-bottom/multi-stripe-957/27470.aspx
收起回复
  • 相关推荐
  • 热点推荐
  • 防护
