22W音频放大器电路 (22W audio amplifie
功率放大器电路图
372人已加入
22W音频放大器电路 (22W audio amplifier)
The 22 watt amp is easy to build, and very inexpensive. The circuit can be used as a booster in a car audio system, an amp for satellite speakers in a surround sound or home theater system, or as an amp for computer speakers. The circuit is quite compact and uses only about 60 watts. The circuit is not mine, it came from Popular Electronics.
音频放大器
Parts
Part Total Qty. Description
R1 1 39K 1/4 Watt Resistor
C1,C2 2 10uf 25V Electrolytic Capacitor
C3 1 100uf 25V Electrolytic Capacitor
C4 1 47uf 25V Electrolytic Capacitor
C5 1 0.1uf 25V Ceramic Capacitor
C6 1 2200uf 25V Electrolytic Capacitor
U1 1 TDA1554 Two Channel Audio Amp Chip
MISC 1 Heatsink For U1, Binding Posts (For Output), RCA Jacks (For Input), Wire, Board
Notes
1. The circuit works best with 4 ohm speakers, but 8 ohm units will do.
2. The circuit dissipates roughly 28 watts of heat, so a good heatsink is necessary. The chip should run cool enough to touch with the proper heatsink installed.
3. The circuit operates at 12 Volts at about 5 Amps at full volume. Lower volumes use less current, and therefore produce less heat.
4. Printed circuit board is preferred, but universal solder or perf board will do. Keep lead length short.
