低阻抗麦克风放大器电路 (Low impedance mic
功率放大器电路图
372人已加入
低阻抗麦克风放大器电路 (Low impedance microphone amplifier)
The circuit is a microphone amplifier for use with low impedance (~200 ohm) microphones. It will work with stabilized voltages between 6-30VDC. If you don't build the impedance adapter part with T1, you get a micamp for higher impedance microphones. In this case, you should directly connect the signal to C7.
麦克风
Layout of board
麦克风
printed PCB
麦克风
Parts
R1=15k   C1= 3k9   U1= TL081
R2= 150k   C2= 100u   D1= 1N4148
R3= 2k2   C3= 22u   CN1= SIL6
R4= 820   C4= 4u7
R6= 10k   C5= 470u
R7= 10k   C6= 10u
P1= 1M   C7= 100n
    C8= 47u UNIPOLAR
