场效应管音频混合器 (FET Audio Mixer)
音频电路
159人已加入
This simple circuit mixes two or more channels into one channel (eg. stereo into mono). The circuit can mix as many or as few channels as you like and consumes very little power. The mixer is shown with two inputs, but you can add as many as you want by just duplicating the "sections" which are clearly visible on the schematic.
混合器
Schematic
Parts
Part
 Total Qty.
 Description
R1, R3
 2
 10K Pot
R2, R4
 2
 100K 1/4 W Resistor
R5
 1
 6.8K 1/4 W Resistor
C1, C2, C3
 3
 0.1uF Capacitor
Q1
 1
 2N3819 Junction FET
MISC
 1
 Wire, Shielded (Metal) Case, Phono Or Other Plug For Output
Notes
1. As many or as few channels as are required can be added to the mixer. Do this by just duplicating the input "sections" which are clearly shown on the schematic. One version of this mixer I saw had 25 inputs!
2. A shielded case is probably needed to reduce hum and help stop oscillations.
3. The circuit can be powered by a single 9 volt battery.
