声级计电路 Sound Level Meter
音频电路
159人已加入
This nifty sound level meter is a perfect one chip replacement for the standard analog meters. It is completely solid state and will never wear out. The whole circuit is based on the LM3915 audio level IC and uses only a few external components.
Schematic
Original Schematic
Parts
Part
 Total Qty.
 Description
C1
 1
 2.2uF 25V Electrolytic Capacitor
R1
 1
 1K 1/4W Resistor
D1
 1
 1N4002 Silicon Diode
LED1-LED10
 10
 Standard LED or LED Array
U1
 1
 LM3915 Audio Level IC
MISC
 1
 Board, Wire, Socket For U1
Notes
1. V+ can be anywhere from 3V to 20V.
2. The input is designed for standard audio line voltage (1V P-P) and has a maximum input voltage of 1.3V.
3. Pin 9 can be disconnected from ground to make the circuit use a moving dot display instead of a bar graph display.
  • 相关推荐
  • 热点推荐
