采用LM386制作的微小音频放大器电路
功率放大器电路图
372人已加入
采用LM386制作的微小音频放大器电路
The Tiny Audio Amplifier kit is a good choice for battery operation.  It is based on LM386 IC.
Power supply - 6 - 12 VDC
Output power - 1 W, 8 Ohm
The quiescent power drain is only 24 mW when operating from 6 VDC
Self-centering output quiescent voltage
Onboard PRESET to adjust volume
Terminal pins for connecting power supply, audio signal and speaker
Power-On LED indicator
ON/OFF PCB mounted slide switch for power supply
Four mounting holes of 3.2 mm each
PCB dimensions 44 mm x 44 mm
Parts List
Inputs - Outputs configuration
pcb
评论(0)
发评论
zux 2016-09-15
0 回复 举报
好,赞! 收起回复
1091662915 2013-05-04
0 回复 举报
收起回复
全部评论
