音频电路
使用LA3161的前置立体声磁带头电路-Stereo tape head preamplifier using LA3161
Specifications
The Stereo Tape Head Preamplifier kit is based on LA3161 IC from SANYO.
Power supply - 9 ~ 12 VDC @ 20 mA
Output power - upto 200 mW
Input Resistance - 100 KΩ (Typ), Load Resistance - 10 KΩ (Typ)
Low noise, good ripple rejection owing to the on-chip voltage regulator
Berg pins for connecting power supply, input and output
Power-On LED indicator
Four mounting holes of 3.2 mm each
PCB dimensions 51 mm x 54 mm
Parts List
pcb
