布线技巧与EMC
Problem
Will you fab (cut/route) my panelized boards?
Solution
We do offer the precise routing feature on our PCB123™ services, routed to most any board perimeter shape, limited to 1 pass with a .093 router bit (No internal cutouts).
We will only cut out the main panel and will not cut smaller boards from the panel. You will need to submit each smaller board as its own design, or cut them apart yourself. We do not do internal cutouts or tab routing.
