如何正确的选择音圈电机模组
今日头条
1193人已加入
昆山同茂电子有限公司深耕于直驱产品领域十余年,主营产品包括直线电机、摆动电机和系统集成,其中的系统集成指的是直线电机模组和音圈电机模组。
在两大类系统集成中,音圈电机模组每年的出货量占总系统集成产品出货量的百分之七十以上。
那么,对于同茂造音圈电机模组,如何进行正确的选型呢?首先,先要了解同茂音圈电机模组的组成结构,同茂音圈电机模组由音圈电机、驱动器、编码器、结构零部件等组成,故除了要选择合适的音圈电机外,还要选择合适的驱动器、编码器等。
同茂音圈电机命名是有讲究的,譬如TMEC0005-005-000,即指峰值推力为5N,动子行程为5mm,序列号为000的圆柱型音圈电机,故要选用峰值推力为5N,动子行程为5mm的音圈电机模组即可选这款电机。譬如TMER0022-032-000,即指峰值转矩0.22,总摆动角度32度,序列号为000的摆动型音圈电机,故要选峰值转矩0.22,总摆动角度32度的音圈电机模组即可选这款电机。当然音圈电机模组的选型还要考虑使用环境,譬如体积要求、温度要求、湿度要求等,如把握不准,请电联400-007-7724。
      责任编辑:tzh
评论(0)
发评论
h1654156022.1315 2022-08-23
0 回复 举报
http://house.china.com.cn/sousou/%25BE%25AD%25C0%25ED%252C%2B%25C3%25E5%25B5%25E9%25F6%25CE%25B0%25DB%25C0%25FB%25C1%25AA%25CF%25B5%25B7%25BD%25CA%25BDB2024.cN%252C%25D6%25DC%25BF%25DA%25B7%25D6%25B9%25AB%25CB%25BE_3s.htm http://house.china.com.cn/sousou/%25D4%25DA%25CF%25DF%252C%2B%25F6%25CE%25B0%25D9%25C0%25FB%25CA%25C7%25D5%25FD%25B9%25E6%25B5%25C4%25C2%25F0B2024.cN%252C%25D1%25CC%25CC%25A8%25B5%25E7%25D0%25C5_2s.htm http://house.china.com.cn/sousou/%25C3%25E5%25B5%25E9%252C%2B%25C3%25E5%25B1%25B1%25CC%25DA%25C1%25FA%25B9%25FA%25BC%25CA%25C6%25BD%25CC%25A8B2024.cN%252C%25C0%25A5%25C3%25F7%25B8%25DF%25D0%25A3_4s.htm http://house.china.com.cn/sousou/%25C6%25F3%25D2%25B5%252C%2B%25B2%25FD%25CA%25A2%25D3%25E9%25C0%25D6%25B3%25C7B2024.cN%252C%25CE%25C2%25D6%25DD%25D2%25DF%25C7%25E9_2s.htm http://house.china.com.cn/sousou/%25CA%25D6%25BB%25FAAPP%252C%2B%25F6%25CE%25CA%25A4%25D3%25E9%25C0%25D6%25CD%25F8%25D2%25B3%25B5%25C7%25C2%25BCB2024.cN%252C%25D0%25C2%25D3%25E0%25C8%25CB%25C1%25A6%25D7 收起回复
