Fairchild - FSUSB46 超低的电容值0.2
新品快讯
29人已加入
Fairchild - FSUSB46  超低的电容值0.2PF
产品规格 .Low On Capacitance: 7.0pF Typical
.Low On Resistance: 3.9Ω Typical
.- 15μA Maximum ICCT over an Expanded Voltage
Range (VIN=1.8V, VCC=4.3V)
.Wide -3db Bandwidth: > 720MHz
.Packaged in Pb-free, 8-Lead MicroPak™ (1.6mm
wide), US8 (3.1mm wide), and UMLP (1.4x1.4mm)
产品特性 .Low Power Consumption: 1μA Maximum
.8kV ESD Rating, >16kV Power/GND ESD Rating
.Power-Off Protection on All Ports When VCC=0V
- D+/D- Pins Tolerate up to 5.25V
产品应用
文字介绍 The FSUSB46 is a bi-directional, low-power, Hi-Speed,
USB2.0 switch. Configured as a double-pole, singlethrow
switch (DPST) switch, it is optimized for switching
a Hi-Speed (480Mbps) source.
The FSUSB46 is compatible with the requirements of
USB2.0 and features an extremely low on capacitance
(CON) of 3.9pF. The wide bandwidth of this device
(720MHz) exceeds the bandwidth needed to pass the
third harmonic, resulting in signals with minimum edge
and phase distortion. Superior channel-to-channel
crosstalk also minimizes interference.
The FSUSB46 contains special circuitry on the switch
I/O pins for applications where the VCC supply is
powered-off (VCC=0), which allows the device to
withstand an over-voltage condition. This device is
designed to minimize current consumption even when
the control voltage applied to the /OE pin is lower than
the supply voltage (VCC). This feature is especially
valuable to ultra-portable applications, such as cell
phones, allowing for direct interface with the generalpurpose
I/Os of the baseband processor. An additional
feature is the detection of the 1-1 (high/high) state on
D+/D- to signal an interrupt (INT) to the processor when
entering a dedicated charging port mode of operation.
【INPAQ - EGA10402V05AH】
  产品规格 单路Varistor
封装:0402
工作电压: Vdc:5V
产品特性 ‧Leakage Current: 0.05u A
‧Capacitance: 0.2 pf
‧Trigger voltage: 100v
‧Clamping Voltage:17v
产品应用 Applications for RF Module, Antenna circuit,ieee-1394, USB2.0,DVI, HDMI and displayport ……etc. Hight speed signal interface
文字介绍 1.ESD 保护器件: 单路 Varistor.
2.完全符合ICE6100-4-2 Standard Lever 4 For ESD 15KV(AIR), 8KV (Contact)的行业标准.
3.超低的电容值0.2PF, 可确保信号的传送完全不受干扰, 适用在HDMI,USB 等端口
