豪华充电速率限制器的小容量镍镉电池电路
充电电路
115人已加入
豪华充电速率限制器的小容量镍镉电池
Here is a deluxe version of the simple charge rate limiter, using the same idea but with the ability to charge two packs simultaneously from a single wall charger. For circuit description and parts list, see the simple charger page. Since wall chargers provide about 55 mA, you should not use this dual circuit to charge batteries at rates greater than 27 mA (for a total of 54 mA).
镍镉电池
镍镉电池
镍镉电池
镍镉电池
