ADL5536应用电路 (20 MHz to 1.0 GHz
新品快讯
30人已加入
ADL5536应用电路 (20 MHz to 1.0 GHz IF Gain Block)
应用电路
Figure 10 shows the schematic for the ADL5536 evaluation board. The board is powered by a single 5 V supply. The components used on the board are listed in Table 4. Power can be applied to the board through clip-on leads (VCC and GND).
Table 4. Evaluation Board Configuration Options
Component Description
Default Value
C1, C2
AC-coupling capacitors
0.1 μF, 0402
L1
DC bias inductor
470 nH, 0603 (Coilcraft 0603LS-NX or equivalent)
VCC and GND
Clip-on terminals for power supply
C4, C5, C6
Power supply decoupling capacitors
C4 = 68 pF, 0603; C5 = 1.2 nF, 0603; C6 = 1 μF, 1206
